Results 1 to 4 of 4
Thread: Installing a catchcan= need a tuning?
    Dec 2007
    Quebec
    3,209
    I heard because a catchan add more air to the engine you need a tune adfter this mod? does the added air matters that much?
    thanks!
    Ovechkin is the best player.
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,894
    not true at all
    cortexx's Avatar
    Apr 2010
    Turkey Point , Ontario
    1,070
    The differences are miniscule , the ECU will make the adjustments by utilizing the data from the MAFS and O2 sensors .
    It's only because the stock PCV system does return some contaminated and unburnt fuel / oil from the crank case into the intake. Once you use a catch can (depending on how you set it up ) the engine does not have to burn the junk anymore.
    Mar 2005
    Calgary
    385
    If you eliminate the PCV by blocking it completely and reroute all Valve cover hoses to the catch can, then there is no added air. Otherwise, if you keep the PCV connection, then, when the engine is in vacuum, it will draw air from the catch can.
    Quote Originally Posted by cobrAA View Post
    thanks!
  1. Replies: 3
    Last Post: 01-29-2011, 09:06 PM
  2. installing blitz sbc-id3
    By zedd in forum GT-R Tech
    Last Post: 03-09-2008, 03:33 PM
  3. Installing a new clutch
    By TR3CK in forum GT-R Tech
    Last Post: 08-10-2006, 01:19 AM
  4. RB26 CatchCan Diagrams
    By pmdawg in forum GT-R Tech
    Last Post: 08-10-2005, 12:37 PM
  5. installing avcr help plz
    By DrMango in forum GT-R Tech
    Last Post: 08-04-2005, 12:47 AM
