Results 1 to 8 of 8
Thread: Valve Clearance Specs on A/M setup?
    GTRCer caliber676's Avatar
    Feb 2008
    Burnaby
    1,382
    heys guys. So I am going to be running new valves, guides, springs, retainers and cams. I am wondering if the valve clearance specs of 0.45mm on the stock head would still apply to an aftermarket setup such as this. I am unsure if I am going to use a "drop-in" cam (Poncam type a/b, etc) or something with a lift over 10mm, but would this affect the specs? Just trying to figure this all out.... and to source the shims
    Thanks for any help.
    Jun 2004
    Windsor, Canada
    1,992
    I was actually just about to post this same thread because I'm in the same boat. I'm running stainless valves now and they expand at a different rate than stock.
    IMO the stock clearances are real, real loose and I'm not sure why. Bike heads set up the same way run 1/4 of the clearance compared to the GTR head. There must be a reason but I don't know what it is.
    I planned on baking my valves and measuring them and comparing to the stock expansion rates. I'll post back here with what I find.
    1992 GTR
    1988 Mazda RX-7 10AE
    1999 F250 Superduty 7.3L Turbo (tow vehicle)
    Feb 2008
    Burnaby
    1,382
    sounds good man. If anyone could shed some more light on this that would be great.
    Feb 2008
    Burnaby
    1,382
    Anyone got any ideas?
    Aug 2008
    the moon
    348
    use oem specs..... the tomei genesis we got in with a full built head oversize valves and the whole 9 still run .38mm and .45mm just like stock
    cheers
    GTS4-R
    Jun 2004
    Windsor, Canada
    1,992
    How's your head sound? Noisy or quiet?
    I did extensive googling and find that many people just run stock clearances, though tomei apparently lists (this is 2nd hand knowledge, I didn't read it myself) 12 and 15 thou for their camshafts.
    1992 GTR
    Aug 2008
    the moon
    348
    in or mm? .015in is .38mm
    GTS4-R
    Feb 2008
    Burnaby
    1,382
    good enough for me, Thanks guys.
  1. Valve clearance help! Pictures inside
    By bellis_GTR in forum GT-R Tech
    Last Post: 07-24-2011, 02:15 AM
  2. rb25 neo valve lash specs
    By fcmax in forum GT-R Tech
    Last Post: 08-04-2010, 08:00 PM
  3. Need RB26 Engine clearance specs
    By jdms13rhd in forum GT-R Tech
    Last Post: 08-30-2006, 01:34 AM
  4. Valve Clearance Intake/Exhaust?
    By Waders in forum GT-R Discussion
    Last Post: 03-17-2006, 11:46 AM
  5. What is the stock valve clearance on a rb26?
    By Waders in forum GT-R Tech
    Last Post: 03-09-2006, 07:45 PM
