Results 1 to 3 of 3
Thread: messed up engine, timing issue...
    Jun 2011
    Beaumont
    31
    hey guys. finally got my engine running again today...but its still running like poop.
    I pulled the plugs..all of them just caked in black crap. this is from 3 months driving...
    checked compression, numbers as follows from front to back of engine: 130,120,140,140,140,130. how do these numbers look?
    i checked timing and it looked way off, i was reading off the loop at the back of the engine. had to turn my cas all the way Clockwise to even get it close to the 20* mark..
    slightly low idle, punch the throttle and a little black smoke out the tail pipe(rich?)
    I should point out the the engine is pretty much all stock, except for pod filters, downpipe and exhaust. injectors are new oem replacements that i installed three months ago along with new fuel filter.
    Right now Im thinking maybe one of my cam gears slipped a tooth?
    any thoughts would be very helpful and appreciated, thank you!
    GTRCer Gordoskin's Avatar
    Aug 2009
    Central Alberta
    116
    Did you do wet and dry compression test? The manual states a rebuild with numbers that low on a stock setup. Valves are probly wrecked due to timing being out. Maybe I am wrong, just a guess
    1992 Skyline GTR - Garage Queen
    2009 Dodge Caravan - Woopee
    1989 240sx - Rusty Beater
    1979 Nomad Skyline - 23' Camper Trailer
    Jun 2011
    Beaumont
    31
    ok, heres an update. i found out that reading off the loop at the back of the engine gives off readings unless you use a nissan timing light... got the timing sorted now but its still running rich enough to foul plugs in a short period of time. i dont quite understand because its pretty much all stock. ive started looking for vacuum leaks.
    as for the compression test, i understand that 130 is ok as long as its consistent. im worried about the #2 cylinder with 120.
    and also i didnt do a wet test, slipped my mind and i wasnt about to take all the plugs out again.
  1. DSPORT august 2011 issue (has an engine blueprint guide)
    By collector240sx in forum GTRC OT Pit
    Last Post: 07-09-2011, 12:26 AM
  2. WTB engine cover gaskets (cam, timing and so on)
    By Bruizer in forum Want to Buy
    Last Post: 05-26-2011, 11:47 PM
  3. How to set base ignition timing properly on RB engine
    By Skym in forum General Skyline Tech
    Last Post: 01-02-2011, 08:18 PM
  4. timing issue
    By jdmnewf in forum GTS Tech
    Last Post: 05-20-2008, 11:30 AM
  5. Messed up wiers...
    By GTRIDER in forum GTS Tech
    Last Post: 08-02-2006, 08:53 PM
