Results 1 to 6 of 6
Thread: Coilpacks alternative, finding a different coils that migh work, waste spark discussi
    GTRCer tryingtobebest's Avatar
    May 2007
    Calgary, AB
    296
    LS2 TRUCK Coils - Coilpacks alternative, finding a different coils that migh work
    FINAL UPDATE:
    I did an extensive research and find out that the best coil to use is GM LS2 TRUCK coil, also known by the name YUKON coil
    They are just amazing pieces and "SMART" too, so we eliminating the factory ignitor as well.They are very recognizable from the rest of the coils because they have small heatsink on top of them and this means that they can take abuse of increased DWELL setting.
    Here is the cool video where guy testing some GM coils:
    ORIGINAL POST
    Im qouting couple of thread from random threads in order to get best replacement ignition coils (alternative for a stock ones)
    Here is qotation from GTRCO.UK
    http://www.gtr.co.uk/forum/99005-any...ark-setup.html
    Quote Originally Posted by Lith View Post
    From factory yes - however a lot of aftermarket ECUs only have 4 ignition drivers so when running on 6cylinder cars they run as wasted spark anyway. The downside with that is with RBs you have coils which were designed to be direct fire being used as a wasted spark setup, its working at 7000rpm like it would if you were running at 14000rpm.
    I went to wasted spark on my Skyline because my ECU is one of those which only have 4 drivers and my coils (which were already around 100,000km old) didn't take long to give in to the load and start missing - and it made complete sense to replace the coils with ones designed to fire twice per complete cycle.
    I strongly disagree with this because my stock engine but turboed 95 Altima having ONE coil and a 4 spark plugs redlined at 7k rpm, which means that the coil is working close to 28k rpm, and i never have any spark cut out problems!
    Here is another qoutation where guy installed 6 Nissan coils (Altima/Stanza, Maxima, ETC) to an RB motor, here i strongly belive that this kind of ignition which is designed to work with 4 cylinders and now working only on one will have much better and stronger spark compare to any kind of aftermarket ign coil we might think!
    Quote Originally Posted by fletch.rb30 View Post
    You can keep the sequential ignition, just grab 6x coils off 88-95 nissan u12/u13/p10/p11(early) j30/a31(fwd) and some n13/n14/n15, they can be triggered off the factory ignitor, or if you have igniter-less r33/34 you can hook up an igniter from any r32/33 or v6 vg20/25/30.
    Also puts out more power than stock coils and splitfires.
    I have since tidied up since this photo was taken
    Ill have to add much more info to here, but im after an inexpensive coil setup, because i cannot pay $500 for a set of coils which i don't think even worth it!
    GTRCer Marus92's Avatar
    Jun 2010
    Bathurst NB
    854
    Very interesting, I'm subscribing in case there's some developments.
    May 2007
    Calgary, AB
    296
    Here is my neighbour Charlie, he did a very cool upgrade, where he install this Yukon coils in the stock location point!!!! Looks very good and works amaizing!!!
    POST #43
    Project Dry Sump
    Besides, if you type RB LS2 Coil in google image search you will find alot of different set ups whre people using this Coils!
    Huh that was close call for me, because i almost bought Splitfire's.....
    ... I cant belive i didn't find out about this coils earlier!
    Here is some cool examples:
    Willis's Avatar
    Jul 2006
    Whitecourt, AB
    513
    I've been looking to do this for a long time, well before I even knew someone had done it before. I also plan on running my FD on LS2 coils as well. They are cheap, plentiful and probably the best stock coils available. Not exactly sure why GM made such a heavy duty coil for a simple truck engine, but I'm glad they did.
    We just need someone on here or another board to make a simple plug and play harness for those of us that are wiring illiterate
    R32.4 GTR
    Willis's Avatar
    Jul 2006
    Whitecourt, AB
    513
    Oh, and for more info on how it's done here is a pretty informative thread
    http://forums.nicoclub.com/ls2-truck...p-t478565.html
    R32.4 GTR
    Mar 2005
    Calgary
    385
    Anton, those are good findings. I'd have them mounted this way if my dry sump plumbing was not in the way.
  1. rb20 spark plugs work in rb26?
    By love_boost in forum General Skyline Discussion
    Last Post: 08-15-2010, 04:39 PM
  2. Replies: 3
    Last Post: 04-11-2010, 10:44 PM
  3. FS: waste spark setup plus a few other things ..
    By NISMONEWF in forum Parts for Sale
    Last Post: 08-17-2008, 03:25 PM
  4. waste spark setup
    By NISMONEWF in forum GTS Tech
    Last Post: 02-02-2007, 08:17 PM
  5. GTR-Proto alternative concept (IAC)
    By GTR-Rich in forum Media
    Last Post: 01-10-2006, 11:58 PM
