Results 1 to 8 of 8
Thread: Hard cornering + hand brake light flickered?
    GTRCer gezed's Avatar
    Nov 2010
    Vancouver
    228
    So i was doing some spirited driving last night around some curvy roads, i was goin around 90-100kph around a bend and my hand brake light(exclamation mark) flickered for a second...should i be worried? Nothing else seems wrong at all
    GTRCer derk's Avatar
    Dec 2005
    Coquitlam, BC
    1,476
    brake fluid level is probably low
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    ^ x2....100% your brake fluid needs topping off.
    Nov 2010
    Vancouver
    228
    cool, thats a relief thanks!
    Apr 2011
    GTA
    41
    Change your brake pads unless you have a puddle in your driveway. That fluid has to be going somewhere. Don't just top it up.
    Nov 2010
    Vancouver
    228
    my pads still have plenty of meat left in them, but ill keep an eye out for puddles but i regularly park at certain spots and im always keen on checking if i leave puddles around.
    but come to think of it, i did have my 300's brake master cylinder let go and that hand brake light was basically on the whole time and it went through brake fluids very fast, hopefully its not the case this time
    Jun 2008
    1,987
    Don't forget rotors. With ceramic pads the rotors are the ones that tend to get eaten up.
    Dec 2005
    Coquitlam, BC
    1,476
    you should never have to top up brake fluid unless you're flushing/ bleeding the system, if there are no leaks and your fluid is low, its indicating that your brake pads are wearing out, provided that you filled the brake fluid to the full line when you did the brakes.
    you never top up fluid with used pads because when you go to compress the pistons when putting new pads in, the reservoir in the bmc will over fill and brakefluid will spill every where.
  1. Hard Brake Pedal...sometimes
    By Marke in forum GT-R Tech
    Last Post: 04-27-2011, 10:15 PM
  2. replacing hard brake lines with braided, bad idea?
    By R32GT-R in forum GT-R Discussion
    Last Post: 02-18-2008, 12:27 AM
  3. E-Brake light always on?!?
    By Mistermark in forum GTS Tech
    Last Post: 01-28-2008, 03:27 AM
  4. E-Brake light on!!
    By JR in forum GTS Tech
    Last Post: 11-10-2006, 09:47 PM
  5. how to adj. hand brake
    By felixy69 in forum GTS Tech
    Last Post: 05-13-2005, 01:36 PM
