Results 1 to 3 of 3
Thread: setting itb"s throttle stops?
    Jul 2008
    Alberta
    1,798
    i just swapped an rb26 into my gts, motor came in peices so i put humpty back together again, but it seems like really laggy like not getting full throttle and the only thing i can think of is the throttle adjustment is wrong. i adjusted the throttle linkage up top, but it didnt seem to solve much, so im thinking about adjusting the itb's themselves and im wondering how i should go about doing it to make sure i get wot. driving around on the street its got the normal lag, but it still feels like somethings holding back, and when revving the engine in nuetral it doesnt seem to rev as fast as my rb20. im running a big single, i doubt this is the reason. i have never had it tuned or anything to this point want to make sure its running 100% which its not before it goes on the dyno. i know what turbo lag is, but it shouldnt take that long to spool, and when i hit full boost it feels like the cars only at half throttle, like no kick just kinda flat.
    any suggestions help, but im really curious if anyone has touched the itb's so i know what to set them at? i looked through the manual and couldnt find anything apart from the main adjustment?
    Aug 2008
    the moon
    348
    check base ignition timing..... DONT use that stupid pickup loop on the back, either clamp the inductive pickup for the light right around the primary wires to the #1 coil OR use a makeshift plug wire from the coil to the #1 spark plug and clamp that (preferable method)...... trust me
    GTS4-R
    Aug 2008
    the moon
    348
    ? any update?
    GTS4-R
  1. " random highway stops"
    By M-type in forum RHD Legal Information
    Last Post: 03-16-2012, 09:24 PM
  2. setting tps?
    By 93_jdm_fd in forum GT-R Tech
    Last Post: 09-06-2011, 09:17 AM
  3. GTR hesitation/ almost stops itself
    By skyrider32 in forum GT-R Discussion
    Last Post: 06-13-2011, 08:24 PM
  4. Replies: 8
    Last Post: 03-28-2011, 08:43 PM
  5. Air Vents "Clicking" on certain setting
    By 604CEFIRO in forum GTS Tech
    Last Post: 01-25-2006, 09:40 PM
