So I have both the 4wd and abs lights on. Check the boot for codes and get 9(abs act relay or circ), 18(ets pressure switch), 19 (ets motor, motor relay, circ). I put in a new relay in the boot already and just had the ets motor (with pressure switch) changed out for a working one. Battery was disconnected and everything was reset BUT i still get all the same codes! I havent changed the abs relay yet but that couldn't be causing the other codes to still come up after everything said has been replaced? Im completely lost and out of ideas! Experts and everyone else please chime in because I dont know where to go from here.
LinkBack URL
About LinkBacks
