GTR manual says that the front brake rotors are 296mm in diameter and the rear are 297mm.
I ordered a set of DBA 4000 rotors for the car and when I tried to install them I found that the caliper doesn't clear the rotor. Upon further investigation I found that the rotors that are currently on the car (some unknown aftermarket part) are actually smaller than 296mm. Was there a different stock brake setup available? Or are the brakes from a GTS-T compatible with the GTR?? I'm starting to think this car is a total hack job and need to find some answers.
I checked the DBA website and the front rotors for the GTS-T are 280mm in diameter which would definetly fit on this car....which worries me! I didn't have a measuring tape available at the time so I didn't check the diameter of the rotors that are on there now, I just did a visual inspection.
Any ideas would be greatly appreciated!!!
Thanks guys!
-Kenji
LinkBack URL
About LinkBacks
