Results 1 to 10 of 10
Thread: no boost
    Jul 2011
    quebec
    32
    no boost
    So here is the story, get my car and take it for a spin, 0 boost. Gauge and boost controller not getting anything. Checked vac leaks and found none, so i hook up a home made pressure tester for my IC/Bov/pipping. at about 2 psi of pressure i hear a hissing sound and the listen around and find the blow off valves leaking air. Could my no boost problem come from the BOV opening under so little pressure or should i be looking somewhere else?
    Feb 2011
    Nashville TN, Seoul Korea
    15
    sounds like you found it. There is good reason why I threw out my stock BOV as well as the entire recirc piping system.
    I ran the SSQV, but that couldn't hold the boost I am running, so I swapped for a HKS Racing BOV (single), and I've been good ever since.
    1991 R32, 2860-5 turbos, build documented on gtr.co.uk, 700bhp on 110RON and 1.9 bars boost.
    2003 Audi RS6, Eurocharged Stage 2tune, 525bhp and 530lb/ft torque.
    2010 BMW S1000RR, PCV tune, 210bhp.
    Regional Chairman, GTR Owners Club, http://gtr.co.uk
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    Do not throw out the recirc piping....it is there for a reason. I would start by taking the BOVs off, cleaning it and see what's broken.
    GTRCer Snake556's Avatar
    May 2009
    London, Ontario
    1,958
    Quote Originally Posted by DarkCaporaL View Post
    This. Pull the BOV off. Might just be gunked up and need a cleaning or just a refresh of some internals. Guy I know had his BOV's start venting constantly at 4k RPM, cleaned 'em out, and boost was back.
    '00 Ford Windstar "Rice Killer"
    1994 Nissan Skyline GTR
    Quote Originally Posted by kengeroo View Post
    Feb 2011
    15
    yep, that reason being adding twice as much piping to leak. Once you start pushing big-boy boost, potential leaks become a paramount concern. When you're tuning, less is more.
    Jun 2008
    1,987
    The recirc debate has been discussed 1000 times over and I dont intend to reopen it here.
    Were not talking 1000 hp GTRs here. Nissan R&D added it for a reason.
    Jul 2011
    quebec
    32
    I know of the recirc problem. That was not what I was asking in the first place. The question was more that since the blow off valve is leaking would it cause a 0 boost problem or would i still boost little.
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,162
    You said at 2 psi it opens correct? So that's the most boost your making. From what you describe.
    92 Gtst/Silver bullet
    Jul 2011
    quebec
    32
    that is what the BOv is opening at. The gauge while driving reads 0
    Feb 2011
    15
    I don't run 1000hp, I have a streetable R32. I had lots of boost problems, and throwing out the recirc system helped, but was not the only culprit. Different strokes for different folks.
    At the very least, toss those worthless stock BOVs; many aftermarket BOVs have recirc parts so that they can be incorporated into a recirc system. HKS includes a recirc hose mount with their kits. BOVs cause innumerable boost problems - single is better than double.
  1. Replies: 7
    Last Post: 07-14-2011, 02:23 PM
  2. Replies: 0
    Last Post: 06-20-2011, 05:37 AM
  3. took out the boost restricter but still no boost
    By dawgmode in forum GT-R Tech
    Last Post: 06-22-2008, 09:31 PM
  4. what is stock GTR boost pressure? (was:boost!!!)
    By skygodgtr in forum GT-R Tech
    Last Post: 05-03-2007, 10:57 PM
  5. Replies: 9
    Last Post: 01-28-2007, 12:02 AM
