Results 1 to 4 of 4
Thread: Gear noise coming from under shifter
    Jul 2011
    Edmonton
    9
    So i start my car up last night, And put it in to gear, and notice what sounds like gears in the transfer case as the vehicle is moving. I just finished reinstalling the tranny after a clutch change, and have dumped 2 liters of Nissan ATF D into the transfer case, and reinstalled everything correctly around the shifter, atleast as far as i can remember i did. The shifter boot was torn ever so slightly when the shifter went back in, but it didnt seem bad
    Curious if dumping the fluid down the shifter hole is bad practice? is there some sort of bleeding that needs to be done on the transfer case, or should i just recheck my transfer fluid level from the fill whole?
    Any help would be appreciated, Thanks!
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    its not ATF that goes in there, its literally gear oil
    get some Redline Heavy ShockProof
    it should be pumped from underneath i beileve, read the service manual for exact info
    cortexx's Avatar
    Apr 2010
    Turkey Point , Ontario
    1,070
    you will need 4 litres of heavy shockproof filled through the hole in the SIDE of the gear box. THIS IS FOR THE GEAR BOX , not the transfer case THEY DO NOT USE THE SAME OIL !
    you will need 2 litres of redline ATF ( or the nissan atf if you want to) filled through the transfercase filler hole (on the rear of the case) . Do not fill anything through the shifter hole. There are 2 plugs on the back of the transfercase where the front driveshaft is driven from. Bottom one is drain , top is fill (just to clarify) .
    When you fill the cases, add fluid until it starts to spill out of the TOP HOLES , then your good.
    Sounds to me like you have no lube in the gearbox , which if you drive it like that you will destroy the synchos immediately and destroy the bearings , gears shortly after.
    Jul 2011
    Edmonton
    9
    I am aware they aren't the same fluid, i didn't put ATF in the gear box, i put ATF in the transfer case.
    There was definitely still fluid in the gearbox, as you don't have to open it up in any way to remove the transmission.
    It seems that i just over filled it a bit, and it has stopped complaining now that the excess has leaked out of the overflow tubes.
    http://www.youtube.com/watch?v=jUAMvSGXnPY&list=FLiY-75Vrg_n6PlsqVhdsHxg&index=1
    Most fun ive ever had in a vehicle
  1. Coming soon to AMS INC..................
    By Vuk@AMS in forum AMS-Absolute Motor Specialties Inc.
    Last Post: 12-13-2010, 08:27 PM
  2. Only hot air coming through vents
    By darrenchua in forum GTS Discussion
    Last Post: 08-25-2010, 03:01 PM
  3. COMING MAD GTR PART OUT
    By maximk2 in forum Parts for Sale
    Last Post: 08-13-2010, 04:38 PM
  4. Coming to Skymeet 2K7?
    By sidewazegtsr in forum Eastern Region
    Last Post: 05-24-2007, 09:52 AM
  5. 486 HP GTR Coming!
    By JDM-IMPORTS in forum General Skyline Discussion
    Last Post: 07-27-2006, 11:42 AM
