Results 1 to 6 of 6
Thread: tapping the oil drain hole
    GTRCer ChezoGTR's Avatar
    Apr 2011
    Winnipeg
    63
    Thumbs down tapping the oil drain hole
    just wondering if anyone has had to tap their oil drain hole? mine is starting to look like pooh and is leaking due to previous owner. looking for numbers mainly. like drill bit size tap size.
    DRIVE FOR THE LOVE
    1995 NISSAN SKYLINE GT-R R33 V-SPEC GOHAN
    GTRCer dark_sky's Avatar
    Mar 2011
    brampton
    176
    just for a temp fix try useing teflon tape or check the plug for the o ring or washer.
    just to get you back on the road and so your not leaking oil on you driveway
    1991 skyline GTR
    1969 corvette
    1989 cavalier Z24
    1991 skyline GTR
    1985 VW scirocco
    Apr 2011
    Winnipeg
    63
    i was thinking about using teflon tape. i just dont want to mess up the threads any more then they are
    DRIVE FOR THE LOVE
    GTRCer caliber676's Avatar
    Feb 2008
    Burnaby
    1,382
    it won't distort the threads anymore than they are, just provides a seal for the threads. I would use teflon tape for the time being, But find a tap to match the drain plug, if the threads are too far gone or worn away you will have to re-tap it to the next size up and get a new drainplug.
    Mar 2011
    brampton
    176
    just use this as a band-aid to limp around on till you can research the tap size or get a new/used oild pan. teflon tape is so thin it wont mess up the threads any more then they are
    1991 skyline GTR
    1969 corvette
    1989 cavalier Z24
    1991 skyline GTR
    1985 VW scirocco
    Mar 2005
    Calgary
    385
    I had redrilled mine and retapped to HONDA Spec.
    I think Honda Spec is 14mmx1.5 or 14x2.0mm, please confirm it on your own.
    The stock Nissan drain spec is 12 x 1.25mm, which is every easy to strip.
    Quote Originally Posted by ChezoGTR View Post
  1. Does anyone know what this hole thread is?
    By GTRSOAR in forum GT-R Tech
    Last Post: 08-26-2011, 08:06 PM
  2. Pin hole camera
    By Nexsys in forum RHD Legal Information
    Last Post: 08-03-2011, 09:23 PM
  3. tapping into accessory
    By Matty in forum GT-R Tech
    Last Post: 04-26-2008, 12:41 PM
  4. who is the @$$hole?
    By victoriaGTR in forum Western Region
    Last Post: 12-28-2007, 04:48 PM
  5. Stripped Oil pan Hole...
    By megar32 in forum GT-R Tech
    Last Post: 04-06-2007, 07:32 PM
