Is their any reason not to delete the factory O2's in an engine that will be highly tuned race motor. Ie. big turbos and 280 deg pro cams.
Trust T618Z,Carrillo Rods,CP Pistons,Tomei 280 10.8 lift ProCams, Tomei Spec C Springs, N1 Block, ARP, ATI, ATL, Bosch 044,Sard 800cc,PFC,Z32 etc.......
FS: tomei 2.6 full counter crank, reground/nitrated.
No reason if you are running AM ECU with WB O2.
your signature says you have a PowerFC, just turn off the O2 sensors in the hand control. ETC-->Function Select-->O2 F/B Control
1991 Nissan Skyline GTR (main)
2007 Toyota Tacoma TRD 4 door (baby wagon)
From what I understand, stock narrowband o2 sensor is designed to work with stock cams, good fuel economy at idle, cruise and is ignored by ECU when foot is to the floor (fuel map only). Once you upgrade cams, have to run engine richer (how rich depends on specs of cams / how much air they let into cylinders) and stock narrowband becomes useless (turn it off). Also fuel economy goes out the window due to running engine richer.
cool, dunt it, just put plugs in the holes
I would leave the O2 sensor functioning,
They only work under part throttle to attain 14.7 afr. under wot you are open loop anyways so the 02 sensors are not trimming fuel.
Unless you want poor fuel economy ofcourse.
Bah, hogwash.....I can average 20mpg with my car and I have no O2s. No black crap all over the bumper either, it's all in the tune.
The only reason you will run richer with bigger cams is if you have a lot of overlap. Not that you actually are fueling more but that there is more raw fuel getting into the exhaust and making it richer, then the computer will pull back on the fuel a little and voila, you now have a lean stumble at idle. That's nothing a tweeking can't handle though.
The only reason mine had the O2s removed was because of the steady diet of leaded race fuel. Now that there is no lead here in North America I don't have to worry. I will be putting them back in next year to try to go for 25mpg average.
Rides:
2011 Silverado Crew tow rig.
who is a good tuner in this part of BC?
Tomei mention how rich you run it at idle for different spec cams (stock, 260 duration, 270 duration, etc) -
http://www.tomei-p.co.jp/_2003web-ca...7_te-info.html
With 280 degree cams I gather it would be fairly rich at idle, probably into low 12's at idle and idle rpm would be alot higher (1300rpm?) to stop engine from stalling with those cams due to I gather vacuum being so low at idle with more aggressive cams, stock idle rpm. Of course cam gear adjustments (overlap, etc) probably would affect idle.
From what I understand, stock ECU uses what's inputted on fuelmap as the target A/F ratio (around 14.7:1) and o2 sensor lean, rich trigger voltages (converted to A/F ratio, so know where to adjust them to) are adjusted to be leaner or richer than what's inputted on fuelmap.
