Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: boost issue
    GTRCer ChezoGTR's Avatar
    Apr 2011
    Winnipeg
    63
    boost issue
    so for the past couple days ive been having a boost issue. i washed my engine bay the other day and ever since ive been boosting fine for a bit of driving but then after a while my car will only boost to the line right before +7 (stock boost gauge) and then i turn my car off and let it sit for a bit and it boost all the way up to +7 again and then back down to lets say +3.5. is there such thing as a boost limp mode or is my? or did i mess something up when i washed the engine bay and is now restricting my boost? its using both turbos even when its being restricted it just wont get to full boost. solenoid maybe?
    DRIVE FOR THE LOVE
    1995 NISSAN SKYLINE GT-R R33 V-SPEC GOHAN
    Apr 2011
    Winnipeg
    63
    bumping ( its really bugging me cant figure it out) any suggestions will do. i know its not a vaccume leak
    DRIVE FOR THE LOVE
    GTRCer danwit's Avatar
    Sep 2009
    hamilton
    238
    Wastegate actuators sticking maybe? I dont think washing youre engine would be the cause because the issue is reoccuring sporatically. Its not in limp mode either. Limp mode restricts your rpm, not your boost.
    I canz take this corner at 195k cause i gots AWDZ. Get real.
    Apr 2011
    Winnipeg
    63
    but ill be in full boost and it will just drop to the the 3.5 mark while im in full boost.
    DRIVE FOR THE LOVE
    Apr 2011
    GTA
    41
    Sounds like a boost leak to me.
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    I'd say either you have a leak (BOV starts leaking when it reaches a certain pressure, wastegates, etc.) or the ECU is pulling boost aka switching to boost knock maps if you're running the stock solenoid.
    Sep 2011
    prince albert
    7
    actually i was informed that your boost solenoid actully can go to a limp mode i limit your boost so just by pass it. i went to can tire it was 2.99 for a box of three vaccum line connectors then just by pass it and see if that helps.
    Apr 2011
    Winnipeg
    63
    i washed my engine bay and after that i ran on 5 cylinders i guess because im missing one of the center plate screws and water must have gotten in. im thinking that threw a code and is putting my boost into limp mode. how do you by pass the solenoid
    DRIVE FOR THE LOVE
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,701
    Don't bypass the boost control solenoid, fix the problem (find and replace faulty coilpack). If running on 5 cylinders, stock ECU is probably picking it up as knock (high knock count) and switching to knock maps (knock ignition map, knock fuel map, knock boost duty) to protect engine.
    Jun 2008
    1,987
    What Skym said, if the ECU is limiting boost it's because it's detecting knock, you need to find out why, not bypass what controls your boost...
  1. boost issue
    By 91BNR32GTR in forum GT-R Tech
    Last Post: 08-11-2011, 10:48 PM
  2. boost issue
    By evolution23 in forum General Skyline Tech
    Last Post: 05-26-2011, 09:26 AM
  3. boost issue. need help.
    By weeman in forum GT-R Tech
    Last Post: 10-17-2010, 04:09 AM
  4. R32 GTS-T Boost Issue.
    By jeremyboddy in forum GTS Tech
    Last Post: 08-09-2007, 02:08 AM
  5. motor or boost issue
    By 240wide in forum GT-R Tech
    Last Post: 08-02-2007, 04:40 PM
