Results 1 to 9 of 9
Thread: Oil Leakk =( Need a part number/name.
    GTRCer Dylan19's Avatar
    Jul 2011
    Maple Ridge
    45
    I Have a small oil leak coming from a bolt on the valve cover. Was wondering what you guys think it might be. Is it just a seal or o ring inside? Unbolt, replace, bolt back on? Or will it be more difficult then that? Its my DD and I work everyday so Im trying not to take it apart to see what I need to replace it, but If thats what needs to happen it can be done. Starting to get anoyed of the burnt oil smell slowly dripping onto my downpipe -.-.
    Thanks for your help
    GTRCer ColinR33's Avatar
    Oct 2009
    Edmonton, AB
    479
    Probably just the grommet for that bolt, you can get them from nismoparts.com as part of the engine gasket kit, not sure where you would get just the grommets, could try getting them thru your local Nissan dealer, just have to get the part # off FAST. Other possibility is the cam cover gasket is leaking there, you can get single gaskets for $20 from FRsport.
    Jul 2011
    Maple Ridge
    45
    Thanks colin. Any other thoughts from people or parts #s? Hoping its an easy fix, soon as this is done everythings good to go and she can come out for summer!
    GTRCer bobbo's Avatar
    Aug 2009
    Halifax Nova Scotia
    1,010
    Not the grommet as its not what provides the seal. Valve cover gaskets are available from your local dealer. Should replace the 1/2 moon seals while there. If you want to replace your grommets (recommended) get them through RAW Brokerage. By far the best price for them.
    Have you tried just tightening all the cam cover screws?
    Jul 2011
    Maple Ridge
    45
    I haven't tried tightening the cam cover screws no, just the valve cover bolt that is leaking as it was pretty loose but I didnt want to over tighten it. I may end up just taking the car to the shop that built it to fix it, although if the dealer were to have the valve cover gaskets I doubt it would be very hard to fix.
    Feb 2012
    Ottawa
    24
    ruber grommets get squished over time with heat, re tighten down and see if it helps it barely needs any torque at all
    the gasket are 90% of the time reusable take your cover out clean the gasket and valve cover, apply a super tiny layer of gasket maker if you wanan be safe and re assemble everything
    Mar 2005
    Calgary
    385
    First of all, the bolt there does not look like the correct Screw. Please replace it with a correct OEM screw first, since the OEM screw has a spacer built in.
    Jul 2009
    Vancity, BC
    647
    buy valve cover gaskets from nissan or sponsors....the grommets x20 are expensive at dealerships..$7each
    grommets are like a cushion but does not seal from oil, you can retighten in time but the oem screws will bottom out and stop.......only the valve cover gasket seals oil....and you need x2 half moon seals at the back of valve covers as well..
    300zx pathfinders uses same grommets but only 16 per set...
    you can get the grommets at worldpac locally and use the oem part#...they sell individually
    Toy: RB26
    DD: F23A1
    Jul 2009
    Vancity, BC
    647
    left valve cover gasket x1 - 1327058S11
    right " " "x1 - 1327058S01
    half moon seals need x2 - 1105158S00
    grommets/washers need x20 - 1326858S01
    bolt for grommets need x20 - 13224F6505
    Toy: RB26
    DD: F23A1
  1. GTR ACT part number
    By nissanconvert in forum GT-R Tech
    Last Post: 09-13-2010, 10:09 PM
  2. Need help: what part number is this?
    By Jhun_d5 in forum GT-R Tech
    Last Post: 04-25-2008, 12:53 AM
  3. I need a Subaru part from japan. part number insid
    By WRick in forum Sponsor Forums
    Last Post: 07-27-2007, 09:11 AM
  4. MAF part number
    By mini_me1209 in forum GTS Tech
    Last Post: 08-14-2006, 02:58 AM
  5. HKS part number
    By NISMONEWF in forum General Skyline Discussion
    Last Post: 02-13-2006, 11:47 AM
