Results 1 to 8 of 8
Thread: Hard Starting, rough idle and Wet Plugs??
    GTRCer GodziRRa's Avatar
    Nov 2010
    Manila
    82
    Hi Guys!
    My GT-R is having a starting problem. It would take me to crank the engine twice for it start, but it would start one click if you help it via stepping the gas pedal. And the car stumbles at idle, like it's misfiring. Me and my lads took the plugs to check, one plug is wet. We cleaned it, start again all is well. But after a few rounds of driving, it starts all over again...rough idle and wet plug.
    What do you think is my problem... is it the s. plug or the coil packs. By the way coil pack is split fire d.i, and I've heard of it having some issues as well. Any inputs?
    Aug 2008
    the moon
    348
    check your coolant temp sensor to ecu
    GTS4-R
    GTRCer rolyaT's Avatar
    Sep 2010
    edmonton
    196
    ^ second that. Mines acting up on startup and my wires to my temp sensor have gone to crap. Luckily I got a spare to put in over winter
    Mar 2005
    Calgary
    385
    Could be the one injector is leaking fuel into the cylinder.
    Nov 2010
    Manila
    82
    Replaced the plugs and it started ok. But now after a few days it's starting all over again. I'll plug in my consult later to check the coolant temp signal.
    Quote Originally Posted by xcye View Post
    What's the sign of this mate?
    Nov 2010
    Manila
    82
    Well, consult says no error.
    GTRCer DarkCaporaL's Avatar
    Jun 2008
    National Capital Region
    1,987
    You already know the issue is coming from that cylinder/plug.
    I'd start with the basics, meaning it's either getting overfueled which causes it to foul (leaky injector) or it lacks spark and beomes fouled (could be the coilpack, the plug itself, wiring, etc).
    Nov 2010
    Manila
    82
    Well just found out that the wet plugs has nothing to do w/ it. Changed to new plugs and it's not wet anymore and idles fine. But unfortunately the cold start problem still persists, still have to do the magic pedal press a bit.
  1. Replies: 0
    Last Post: 07-01-2011, 04:56 PM
  2. Rough Idle
    By RB in forum GT-R Tech
    Last Post: 09-11-2010, 04:55 PM
  3. RB25DET - rough idle and afr is way off
    By Tripz in forum GTS Tech
    Last Post: 06-28-2008, 11:22 AM
  4. Rough idle after oil change
    By westfire in forum GT-R Tech
    Last Post: 04-10-2008, 06:15 PM
  5. rough idle (running lean)
    By MikeyRHD in forum GT-R Tech
    Last Post: 10-04-2007, 01:59 PM
