Found the missing banjo bolt at a local fluid specialty shop, so this Nismo line should go in fine now. The hose RHDJapan sent does not look like the one in their picture or the one on my car, but the banjo bolt will make this work. Took 6 hours of calling and driving to find a shop locally that had the metric banjo bolt in stock. Ended up buying one for $13 at a fluid specialty shop.
Also, can this thing be deleted?
The seperation pipe delete bits in this clutch kit just eliminate the loop off that box I have pictured above. I was thinking about having a custom clutch hose the completely deletes that box. Just connect the MC feed hard line to the SC direct. Has anyone done this before?
LinkBack URL
About LinkBacks
