So I haven't driven much at night and last night I was out pretty late and when I pressed the highbeam button nothing happened. So today I took apart the cluster and there is no plug plugged in. And no plug anywhere. What should I do?
I am confused as you say button. Did you push the turn signal stick forward for highbeams or are you talking about the button on the dash surround? The button on the dash surround is for fog lights so if the previous owner didnt have them then they might have removed the associated wiring.
If that isnt it and you have HIDs many people disconnect the highbeams so that may also be the cause.
I second that, my Fog Lights are wired into my AWD computer to switch from 4WD to 2WD. I have my fogs wired up to a seperate switch. Highbeams and "flash to pass" is on the turn signal stock.
Rides:
2011 Silverado Crew tow rig.
