hi i am having coolant leak from my engine, seeping from between the transmission and engine block. where could it be coming from?
Trust T618Z,Carrillo Rods,CP Pistons,Tomei 280 10.8 lift ProCams, Tomei Spec C Springs, N1 Block, ARP, ATI, ATL, Bosch 044,Sard 800cc,PFC,Z32 etc.......
FS: tomei 2.6 full counter crank, reground/nitrated.
i have no coolant hoses running behind the motor so it can't be those
had the same thing happen to me it drips down the right side of the block then runs down the the bell housing quite difficult to find leaks as its crowded, id remove the starter and look of buy, borrow, or use a coolant pressure tester mine was the coolant outlet at the back of the vacuum equalizer manifold
93 laser sold
91 skyline gtst totaled
92 skyline gtr current
I had this problem after a fresh install in my GTR. One of the unreachable banjo bolts/crush washers were leaking on one of the turbos, I could only see it by a small mirror and light while using bright orange coolant. I'm pulling my engine out to fix that rather than tearing out my turbos again lol.
figured it out, it was my heater bypass plug, not tightened enough. no leak now, time to prime the oil system tonight. woot woot!!
congrats man. its the best feeling to be able to crank her over for the first time. good luck
