Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Air Fuel Ratio Of GT-Rs
    GTRCer GodziRRa's Avatar
    Nov 2010
    Manila
    82
    Hello guys!
    For those who have some kind of A/F gauge or monitor from AEM, Innovate, Blitz, HKS, etc. What does your A/F read at idle, cruise, and WOT? And for the gurus out there, what should be the normal A/F ratio of the RB26 at idle, cruise, and WOT?
    Thanks!
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    15 idle
    12 wot
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,572
    Quote Originally Posted by frankiman View Post
    15 idle
    12 wot
    I guess you never cruise... lool
    If I remember right, RB26 cruising would be in between the 12-15. Your always fluctuating the gas. Never seen that on my own, but a friends.
    GTRCer Nvdgtr's Avatar
    Apr 2011
    Brantford, on
    301
    When just cruising; 12-15
    when i punch it, it drops; 9-12? i cant remeber exactly.
    frankiman's Avatar
    Apr 2009
    3,112
    i cruise at 14,5 cuz i have steady footzor
    it should never go lower than 10,5
    too much full and you wash the oil off the cylinder wall, create too much heat from friction and damage ****
    kengeroo's Avatar
    Apr 2010
    vancouver
    591
    does anyone have pics of there AFR's logged on a map???
    frankiman's Avatar
    Apr 2009
    3,112
    Nov 2010
    Manila
    82
    Nice graph bro. Anyways, anyone knows what is the Nissan set A/F ratio on idle, cruise, and WOT for the GT-Rs?
    GTRCer needavdub's Avatar
    Feb 2010
    in my garage
    329
    I'm about 14.6:1 at idle and similar cruising, and about 11.8-11.9:1 under full boost at WOT. Using a Innovate LC-1 wideband and running a Blitz Access tuned ECU with stock turbos @ 15 PSI.
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,701
    The A/F ratio varies depending on what cell ECU is looking at on fuel map. The above dyno graph is the WOT run where it runs across multiple cells when going from left to right of fuel map on stock ECU.
    Stock GTR = 14.7:1 is as lean as it can go at idle and 10.7:1 is richest at WOT. But idle, cruise A/F ratio is affected by o2 sensor, so might be leaner or richer at idle, cruise.
  1. Areomotive efi fuel reg 1:1 ratio
    By jeff in forum Parts for Sale
    Last Post: 11-07-2010, 06:14 AM
  2. GTR A/F ratio questions?
    By cbileske in forum GT-R Tech
    Last Post: 07-23-2008, 10:55 AM
  3. GTR A/F ratio questions?
    Last Post: 07-13-2008, 02:30 AM
  4. RB26 Compression Ratio
    By JD74 in forum GT-R Tech
    Last Post: 05-22-2008, 05:36 PM
  5. a/f ratio gauge install
    By Matty in forum GT-R Tech
    Last Post: 12-17-2007, 12:27 PM
