Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Do luck digital G-sensor
    GTRCer NeptuneGTR's Avatar
    Jun 2009
    Winnipeg
    521
    Just came across this today, can anyone read what it says?? Im intrested in what this thing does.
    I'm thinking it just has a diffrent voltage output than the oem one.
    http://www.do-luck.com/tuningparts/g_sensor/index.html
    NEPTUNE OPTIMUS MAXIMUS
    doc
    doc is offline
    GTRCer doc's Avatar
    Apr 2010
    Mississauga, Ontario, Canada
    330
    from bable fish
    Because high sensitivity digital G the sensor is used, it is the rate of reaction which approximately 30 times is quicker than the genuine sensor. Because of this the signal is output to ATTESA-ETS quickly vis-a-vis the input G on front and back left and right. As for improvement of this rate of reaction the effect is shown with all scenes. Breaking with the corner, after putting in place between, it is possible to show the preponderant fast reaction, in comparison with the genuine sensor which reacts. With 0-400 it reacts to high speed vis-a-vis the G change at the time of start and shift rise. It operates also the braking when reducing speed rapidly, to 4WD is converted can obtain mighty damping force quickly and. Genuine as for the sensor the output upper limit vis-a-vis G has become low. Because the digital G sensor approximately 15% has expanded output, with genuine even in the coordinating point which is not good being attached it can obtain gentle quality with real. Genuine G as an exchange part to the vehicle where the sensor has been broken you can use. Sale at that time of the R32 vehicle being small-sized, the high-level accelerating sensor did not exist. The genuine G sensor has detected G in shaking condition of the pendulum of the oil soaking. It is not indicated in the fault diagnosis and the [te], is deteriorated quality with such as deterioration of the oil with aged deterioration and deterioration of the part. The digital G sensor uses the up-to-date electronic type MEMS digital accelerating sensor, can obtain preponderant stability and reliability by high speed calculating the entire area with the micro-computer. Because car classification private volt/bolt on the coupler has belonged, there is no processing with you can install. BNR32     item turn   #81010 BCNR33     item turn #81011 BNR34     item turn   #81012 Price each ¥42,000 (¥40,000 classified by tax)
    Feb 2009
    N.-B.
    366
    Just use google translater to translate the page.
    http://translate.google.com/translat...r%2Findex.html
    hum, could this be a viable replacement for faulty g-sensors, but still a little expensive.
    04 Sentra - winter beater -
    95 240sx (RB25DET powered)
    95 240sx ( powered)
    89 GTR - Money Pit -
    Jun 2009
    Winnipeg
    521
    Thanks doc, I tried to use a translator but it didn't work for me.
    Yea I messaged rhdjapan about this thing, they said its a direct replacement for the oem sensors, they also said this unit is cheaper than a brand new oem one.
    I guess it just improves on reaction time of the 4wd system.
    doc
    doc is offline
    GTRCer doc's Avatar
    Apr 2010
    330
    so are you going to be the guinea pig?
    May 2008
    Fort Erie
    764
    R u guys aware that sum G-sensors can fixed?
    http://www.skylinesaustralia.com/for...-g-sensor-fix/
    But this would b way better and cheaper than any new stock G sensor would.
    Daryl @ RightDrive's Avatar
    May 2004
    Toronto
    8,046
    It's 30 times faster than the original and cheaper too. That's about the jist of it.
    RightDrive Inc. Parts Manager
    10% off HKS Air Filters!
    GTRCer Xeno-Vibe's Avatar
    Mar 2007
    S.Ontario (London)
    573
    Its $550... + $500 for tax. WTF. :|
    Double track drift, yo.
    (oo sκylιnε oo)
    Apr 2004
    Edmonton, Ab
    545
    The attessa cpu only runs at 10hz on a R32 and 100hz on a r33 so it I'm not sure it will make much of a differnce
    GTRCer skreamz's Avatar
    Dec 2010
    Grande Prairie, AB
    160
    So they're selling a part that's faster than what the car can compute?
    Quote Originally Posted by Super_Dude View Post
  1. ~ GTR R32 Digital Artwork ~
    By Nism0o_o0 in forum Media
    Last Post: 02-23-2011, 12:25 AM
  2. Digital SLR Cameras
    By Turismo in forum GTRC OT Pit
    Last Post: 03-07-2008, 05:10 PM
  3. Digital Speedometer
    By aaronisonfire in forum GTS Tech
    Last Post: 07-08-2007, 08:05 PM
  4. WTB: Digital A/C controller
    By Boyscout in forum Parts for Sale
    Last Post: 07-26-2006, 07:58 PM
  5. R34 Digital display
    By BoostedGolf in forum GT-R Tech
    Last Post: 11-19-2004, 04:49 AM
