Page 1 of 2 12 LastLast
Results 1 to 10 of 20
Thread: BNR32 GTR Having issues with steering stiffening
    GTRCer dak24's Avatar
    Jan 2012
    Dartmouth
    13
    Hey guys, I have a R32 GTR and I'm having issues with the steering. For some reason the steering wheel turns really easy some times, and there's other times its stiff as hell to steer. Any ideas on what the issue could be? I've checked the lines and there's no leaks, the fluid is full, and I've replaced the power steering pump and it still hasn't solved my problem.
    GTRCer floger70's Avatar
    Aug 2009
    Waverley, Nova Scotia
    116
    has hicas been removed? or are you running an aftermarket steering wheel?
    1972 Datsun 510
    2003 GMC Sierra
    Jan 2012
    Dartmouth
    13
    It still has super hicas in it and hooked up
    Aug 2009
    116
    aftermarket steering wheel? if it does make sure the hub that is installed is the proper one for the car with the steering sensor in it. if it doesnt this screws with your hicas and speed sensitive steering and can make the steering stiff etc. also check your fuses
    1972 Datsun 510
    2003 GMC Sierra
    Jan 2012
    Dartmouth
    13
    It still has the stock GTR steering wheel in it.
    Aug 2009
    116
    i would check all the fuses and make sure the system is bleed properly so there is no air in it.
    1972 Datsun 510
    2003 GMC Sierra
    Jan 2012
    Dartmouth
    13
    I checked all my fuses and everything looked fine there, and I haven't found any air in the system at all.
    GTRCer Marus92's Avatar
    Jun 2010
    Bathurst NB
    854
    Quote Originally Posted by dak24 View Post
    Did you check your steering shaft's U joints? My Sentra had the same issue which I let worsen until the steering started locking up while turning...
    Jan 2012
    Dartmouth
    13
    Yup, there's no issues there. It goes back and forth, I can start driving the car and then it will act like there is no power steering but all of a sudden it will be working fine again.
    GTRCer newalliance123's Avatar
    Jun 2008
    Kelowna
    397
    If the hicas screws up it will be tough to steer. When I had hicas installed I noticed with the hicas disconnected it would feel as if there is no power steering. The hicas light will come on. Make sure your's isn't burnt out!
  1. BNR32 Rear Diff Issues
    By bobbo in forum General Skyline Tech
    Last Post: 12-05-2011, 09:08 PM
  2. wtb bnr32-34 power steering pump and bracket
    By fentin fury in forum Want to Buy
    Last Post: 02-13-2008, 04:21 PM
  3. power steering issues
    By FunnyGas in forum GTS Tech
    Last Post: 05-21-2006, 12:59 PM
  4. WTB: Used power steering pump for 90 BNR32
    By Harvey in forum Parts for Sale
    Last Post: 01-19-2006, 05:12 AM
  5. FS: BNR32 Steering wheel ((Used))
    By support@feastauto in forum Sponsor Forums
    Last Post: 11-29-2005, 06:56 AM
