Results 1 to 2 of 2
Thread: R32 GTR Engine Temp Gauge Not Working
    GTRCer dak24's Avatar
    Jan 2012
    Dartmouth
    13
    Hi, I have a R32 Skyline GTR, and I'm having issues with my engine temp gauge not working properly. The gauge ususally reads the engine temp when the car is idling, but as soon as I start driving the car the temp gauge goes right down to cold, and sometimes it doesn't read the temp at all. I've replaced the engine temp sensor, and I've got all the air out of the system, and it's still not work. I am getting warm air through the air ducts but its not hot, so it makes me question if its the thermostat or not. Anyone having any idea what my issue could be?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,701
    Get someone with Nistune tuning software (Nistune dealer / tuner) or Consult (Nissan dealership or Consult program, Consult cable) to check coolant temps via ECU (more accurate). If coolant temps are still dropping while driving, thermostat opening too much can be a cause. When stock thermostat fails, it tends to late open at around 95 degrees and coolant temps reach 95+ degrees. But sometimes it can do the opposite.
    Or someone has fitted a Nismo low temp thermostat (stock coolant temp gauge needle sits below halfway at idle when engine is warm with Nismo low temp thermostat, around 62.5 degrees).
    Stock thermostat should start to open at 78.5 degrees and be fully open around 90 degrees.
  1. R32 GTR Engine Temp gauge not working
    By dak24 in forum General Skyline Tech
    Last Post: 01-01-2012, 09:16 AM
  2. Fuel gauge not working help!
    By M0nkeyMark in forum General Skyline Tech
    Last Post: 06-14-2011, 08:15 PM
  3. Replies: 2
    Last Post: 12-02-2010, 02:26 AM
  4. water temp +oil temp gauge install
    By wakmen in forum GTS Tech
    Last Post: 02-25-2008, 08:47 PM
  5. BOOST GAUGE NOT WORKING!!!
    By kaze in forum GTS Tech
    Last Post: 07-11-2005, 08:07 AM
