Is there a different set of specs for Tomei Poncams or do they just follow the oem specs
Also, the first head i put together had too much valve clearance and it ticked when it was warm, but this time, I may have set the clearances more or less on the tight side, is there anything wrong with that?
for example, feeler gauges show intake valve clearance of .402mm whereas the FSM states that it should be .45+/- .03mm
Any insight would be much appreciated
LinkBack URL
About LinkBacks
