Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Stock bore aftermarket pistons
  1. #11
    GTRCer gezed's Avatar
    Nov 2010
    Vancouver
    228
    I actually had it all done at a local shop and heres the breakdown of the costs:
    bore+hone $190
    micropolish+crank collar fitting $180
    resurface head + block $150
    hot tank block $45
    if you assemble the short block yourself you save yourself quite a lot of money, as long as you check the bearing clearances with pastigauges and have a good torque wrench should be no problem
    oh and about the crank balancing, the shop said it wasn't necessary unless the crank has been damaged or if the new piston/rod's weight is significantly different from stock
  2. #12
    GTRCer GTRADDICT's Avatar
    Jan 2010
    Bathurst NB
    743
    Quote Originally Posted by gezed View Post
    bore+hone $190
    hot tank block $45
    I beleive a stock RB26 crankshaft will start to vibrate at 7200 RPM. I would have it done if everything is opened up already...
    03 lancer DD
    68 gmc w/355 cid rice killer
    R33 GTR. The time is near!!
  1. wtb aftermarket rods and pistons
    By sands in forum Want to Buy
    Last Post: 09-08-2011, 06:05 PM
  2. F.S Stock RB26 pistons and rods cheap
    By skyline_steve in forum Parts for Sale
    Last Post: 09-18-2010, 02:10 PM
  3. stock pistons?
    By racebredz in forum GT-R Tech
    Last Post: 03-08-2008, 03:51 PM
  4. Koyo rad stock or aftermarket?
    By donk_316 in forum GT-R Discussion
    Last Post: 05-18-2007, 01:23 PM
  5. stock bore size?...rb26
    By TennesseeR33GT-R in forum GT-R Tech
    Last Post: 08-25-2006, 03:46 PM
