Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Stock bore aftermarket pistons
    Dec 2011
    Massachusetts, U.S
    12
    Is anyone using aftermarket pistons with stock bore? Usually Ive always gone .20 over to clean up it up a bit and ive heard stories of the pistons not fitting right once they have been through the heat cycle and either have been to loose or to tight after. I have a chance to pick up some stock bore Wiseco pistons for a killer price brand new. Ive also emailed them directly to see what their thoughts are but I thought I would come on here
    Thanks
    GTRCer Dakota_gsx's Avatar
    Jan 2010
    Edmonton, Alberta
    173
    Quote Originally Posted by EggplantS14 View Post
    Thanks
    I would definitely go over bore. that way you know you wont have clearance issues. Dont take a short cut just cause you have a deal through somewhere. I also have a set of weisco pistons if you are interested. not saying all this just to get you to buy them, but it seriously is a good idea to bore out when building an engine. stock is 86mm and i have 5 86.5mm bore weisco pistons with upgraded pins. i would give you the 5 for 250 bucks plus shipping. you would just need to buy a new one from weisco. they were in the car for 2000kms. floated a valve in cylinder 6, had to bore out again. if you are interested.
    But seriously, dont stay with stock size. the pistons are the last thing you want to have troubles with with a rebuild. becuase you have to rip everything apart again.
    GTRCer gezed's Avatar
    Nov 2010
    Vancouver
    228
    I had this talk with a pretty knowledgeable machinst, he said engines such as ours with such high mileage, age and such abuse its not uncommon for the cylinder walls to eventually go out of round, at that point the only thing you can really do is overbore cause you will be losing compression at stock bore even if you rehoned the walls, wear on ringland would be unevenly loaded as well which potentially reduces lifespan of the engine
    GTRCer rolyaT's Avatar
    Sep 2010
    edmonton
    196
    ^ I am a machinist and I approve this
    message hehe
    cschepp's Avatar
    Jan 2008
    _________________
    4,323
    I am going to run my engine till she pops. But when all said is done how much do you think it would be to do all the machine work? I know it will differ I just want to have an idea for when I build a motor.
    Jan 2010
    Edmonton, Alberta
    173
    For just bottom end work, cleaning the block, balancing and polishing the crank, and reassembly, I believe I was around 1500-2000 dollars range.
    Jan 2010
    Edmonton, Alberta
    173
    For labour***
    Dec 2011
    Massachusetts, U.S
    12
    Yeah Ive heard the same thing about all high mileage engines not just the rb series. I might run the stock block for the season and pick up a spare block to build slowly. I only plan on making 450hp and keeping the revs down. Im pretty sure with the proper engine helpers and a good tune this wont be a problem to hold me out till mid summer where I hope to have the other engine built and ready to go.
    GTRCer Billy_Jack's Avatar
    May 2011
    red deer
    102
    Quote Originally Posted by cschepp View Post
    .5 over on mine was $40 per cylinder, just for the bore, theres a start
    GTRCer NismoS-tune's Avatar
    Jun 2008
    Alberta
    4,233
    Just buy some stock sized Cosworth pistons. Save all the cylinder thickness for maximum reliability. You're not gonna see much gainst from .5 overbore.
    lol
  1. wtb aftermarket rods and pistons
    By sands in forum Want to Buy
    Last Post: 09-08-2011, 06:05 PM
  2. F.S Stock RB26 pistons and rods cheap
    By skyline_steve in forum Parts for Sale
    Last Post: 09-18-2010, 02:10 PM
  3. stock pistons?
    By racebredz in forum GT-R Tech
    Last Post: 03-08-2008, 03:51 PM
  4. Koyo rad stock or aftermarket?
    By donk_316 in forum GT-R Discussion
    Last Post: 05-18-2007, 01:23 PM
  5. stock bore size?...rb26
    By TennesseeR33GT-R in forum GT-R Tech
    Last Post: 08-25-2006, 03:46 PM
