Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: dialing adjustable cam gears
  1. #11
    Apr 2004
    Edmonton, Ab
    545
    Like gtrdad said, a lot of things can change cam timing. You need to use your cam gears and find the actual lobe centers and from there you can adjust them on the dyno.
    There is no way of telling the amount of power to gained by doing this because they can be way out to lunch or almost perfect.
    Mine were dialed at +4 intake -1 exhaust and it made considerably more power under the curve. Im not saying these are right for anyone else, you have to find what works for your setup. Im just giving am example.
  2. #12
    Dragon Humper's Avatar
    Mar 2007
    Kamloops BC
    1,551
    As has been already stated, EVERY engine is different and a multitude of things will make your cam timing way off even though they are set to zero on the cam gears. You should set the centerlines to spec and then play with it from there to get the power delievery you want.
    Rides:
    2011 Silverado Crew tow rig.
  3. #13
    Dec 2007
    Quebec
    3,209
    is there a way to dial the cam without beeing on the dyno ( dyno time is expensive) ?
    Ovechkin is the best player.
  4. #14
    GTRCer knate's Avatar
    Nov 2011
    calgary
    120
    sure! just guess and hope its working better!
  5. #15
    GTRCer evilgtr's Avatar
    Jun 2009
    Moose Jaw Saskatchewan
    837
    Theres a great article in the most recent modified magazine showing in detail step by step how to degree cam'w with the engine in the car. They actually printed off a degree wheel and scaled it to size to use for there application. They go into detail about the importance of this and how to do it yourself with only a few simple and inexpensive tools.
  6. #16
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,894
    anyone find this article online? ^ id love to read up on it
  7. #17
    GTRCer BenC's Avatar
    Jun 2007
    Lethbridge, Alberta
    964
    I found a pretty good step by step guide awhile back on nico. Even did it on an RB
    http://forums.nicoclub.com/how-to-de...s-t425466.html
  8. #18
    Aug 2006
    Saskatoon
    373
    oh hai!
  1. WTB: Tomei Type B Cams & Adjustable Cam Gears
    By v8-killer in forum Want to Buy
    Last Post: 01-04-2012, 12:09 PM
  2. Set of HKS Adjustable Cam Gears for RB20/25/26
    By TR3CK in forum Parts for Sale
    Last Post: 07-29-2008, 06:31 PM
  3. adjustable rb26 cam gears asap
    By Eber in forum Want to Buy
    Last Post: 05-11-2008, 08:59 PM
  4. how much do cam gears really help?
    By ryan256 in forum GTS Tech
    Last Post: 05-04-2008, 12:07 AM
  5. cam and cam gears????
    By Easyryder in forum GTS Discussion
    Last Post: 06-14-2006, 10:55 AM
