Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: dialing adjustable cam gears
    GTRCer gezed's Avatar
    Nov 2010
    Vancouver
    228
    this has been discussed a lot on the Australia forums, and it seems that the general consensus is to retard exhaust and advance intake to get more overlap
    anyone with adjustable cam gears mind sharing their adjustments and the differences(if any) it made?
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    you'll need to do it directly on the dyno to get it just right, or else you might set it terribly wrong and not know about it
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,701
    This should help with setting up cams -
    http://www.kelford.co.nz/sole-purpos...eeing-your-cam
    I remember something along the lines of that it said somewhere on that website that more overlap for turbo, less for NA cams. But can't find it again.
    Also read this (what the adjustments to camgears do to powerband, etc) -
    http://www.tomei-p.co.jp/_2003web-ca..._adjust-p.html
    GTRCer evilgtr's Avatar
    Jun 2009
    Moose Jaw Saskatchewan
    837
    I had my cam's degreed at the speed shop on the specifications that Tomei provided to the tuner in a phone conversation. GTR-DAD had his cam's degreed as well to the direct specs from Tomei and the results were huge ! By adjusting the intake exhaust gears essentially aren't you just playing with where your power band will be ?
    GTRCer feyd182's Avatar
    Nov 2006
    Edmonton, Alberta
    697
    Basically it's adjusting the cam timing. Like mentioned above, if done properly good gains will be had. Adjust incorrectly and you could be replacing a head.
    89 Skyline GTR [daily]
    89 Skyline GTS-T [sold]
    GTR-Dad's Avatar
    Dec 2005
    Beaumont, AB
    2,955
    Manufacturer specs are a great place to start.
    Mine were off 3 degrees on the intake and 10 degrees on the exhaust. (Not sure which direction, but I think the exhaust was opening early based on a big fart of black smoke when I turned up the boost)
    Set them to Jun specs and and picked up over 100 (yes, one hundred) AWHP.
    d
    The Beaumont Connection
    Nov 2010
    Vancouver
    228
    ^ lol no way, thats amazing
    in general i hear people getting up to 20-30whp gains from correct cam gear dialing
    Also had a good read about the tomei cams, I got type A's i guess they are already optimized so theres no need to plan with the timing?
    GTR-Dad's Avatar
    Dec 2005
    Beaumont, AB
    2,955
    Don't assume they're right just because they're set to 'zero'. Milled decks change the center distance of the cam pulleys and therefore the timing. Dial the cams as you rotate through the full crank rotation to get a direct measure of when they're fully open.
    These ones were pretty far out! Don't expect this result every time you try this at home. ;_)
    Sep 2007
    South
    6,701
    Tomei cams are like copies of stock cams but with more aggressive specs (lift, duration) hence why they work with stock camgears. They are similar to welding on lobes (to get more lift), regrinding weld, base circle of lobes (to get more duration) to more aggressive specs, but Tomei did it the proper way by making them from new blanks.
    Cam manufacture can regrind the base circle of lobes on stock cams for more hp (I think affects duration, similar to what can be done with adjusting camgears) without affecting cam longevity -
    http://www.kelford.co.nz/regrinds
    Jun 2009
    837
    Thanks Dan, I didn't want to quote any power gains in the event they werent accurate. The gains are substantial when this procedure is done correctly. It is possible to degree cams when they are in the car as well
  1. WTB: Tomei Type B Cams & Adjustable Cam Gears
    By v8-killer in forum Want to Buy
    Last Post: 01-04-2012, 12:09 PM
  2. Set of HKS Adjustable Cam Gears for RB20/25/26
    By TR3CK in forum Parts for Sale
    Last Post: 07-29-2008, 06:31 PM
  3. adjustable rb26 cam gears asap
    By Eber in forum Want to Buy
    Last Post: 05-11-2008, 08:59 PM
  4. how much do cam gears really help?
    By ryan256 in forum GTS Tech
    Last Post: 05-04-2008, 12:07 AM
  5. cam and cam gears????
    By Easyryder in forum GTS Discussion
    Last Post: 06-14-2006, 10:55 AM
