Results 1 to 4 of 4
Thread: Ignition or Fuel need suggestions !!!
    jdmtypes's Avatar
    Apr 2006
    Edmonton,AB
    373
    I'm looking for some direction in tracing a problem. Here's a bit of history, at the start of the season my car was having an issue firing up an running normal. Meaning it would start run for a bit then start to hesitate rpm's would drop up an down an the car sounded like it was going to stall. If I shut it off then it would not turn back over without a boost. It was suggested I change out the alternator which I did with a new one. It seemed to work for awhile, but now its back to doing the same thing, but less frequently. Funny thing is when it hesitates/ almost dies just my aftermarket afr an tach flash on an off too with the hesitation. It almost seems like the car is shutting off an starting back up, no other gauges/or anything in the instrument panel in the car flickers like that durning its episode. Now I have noticed that the last 2 times I have started the car I have to give it a touch of the gas pedal to get it to fire, the car sat for a year an half with a 1/2 tank of fuel in it. That fuel has since been burnt an new stuff put in, the fuel pump was a brand new tomei which got used about 1000KM before the car was stored. Not sure where to go from here, is it ignition issues, fuel issues, electronic issues ? ? ? ? I'm in need of some SERIOUS help !!!!!!!!!!!!
    Thanks in advance for any an all input.
    Ar
    ........Nothing but Good Times........
    GTRCer GTRADDICT's Avatar
    Jan 2010
    Bathurst NB
    769
    TPS and check the batterie with a load test. Your car runs on the batterie which is maintained by the alternator. New fuel filter. You can always look at the MAF solders. Could give the MAF's a clean also.
    Nick
    03 lancer DD
    68 gmc w/355 cid rice killer
    R33 GTR. The time is near!!
    Voodoo_ChildR32's Avatar
    Nov 2006
    Edmonton, Alberta
    1,303
    Fuel pump relay. Rewire your tomei directly to the battery with a new relay and that should do it. I had exactly the same issue and bypassing the factory relay and installing my own directly to the battery solved it. The only thing you need from the factory harness is the fuel pump signal wire, it's what turns the pump on and off with the ignition.
    1989 R32 Skyline GTR SOLD!!!!
    -Bruce Lee
    GTRCer Skym's Avatar
    Sep 2007
    South
    7,852
    Hardwire fuelpump kit -
    http://www.deatschwerks.com/products...stallation-kit
    Random stutter = airleak just behind AFM's.
    Faulty TPS can make engine stall randomly. But incorrectly adjusted TPS (not on idle contact) can make rpm needle drop below idle rpm when slowing down on a hill with aircon, light's, etc on. When TPS is on idle contact, ECU kicks rpm up when slowing down.
  1. Suggestions
    By Nexsys in forum General Skyline Discussion
    Last Post: 06-02-2012, 09:31 PM
  2. Hello all ... Any Suggestions ?!?!?
    By djcasanovar32 in forum GTS Discussion
    Last Post: 06-16-2011, 08:43 PM
  3. Looking for new job, looking for suggestions
    By kelaog in forum GTRC OT Pit
    Last Post: 05-11-2008, 01:13 PM
  4. Suggestions Please...
    By FITZY_07 in forum GTS Tech
    Last Post: 12-23-2007, 06:11 PM
  5. Mod suggestions
    By shore_rider in forum GTS Discussion
    Last Post: 02-04-2006, 09:04 PM
