Results 1 to 3 of 3
Thread: Need help with GTR manual EN245 8.1
    GTRCer R32D2's Avatar
    Feb 2012
    Cobble Hill B.C. Canada
    55
    Can anyone please better explain what this is saying? Is it that the fuel system WILL cut out once you have held the revs at 2000 for the second time, and if it doesn't repeat the whole process, or just repeat the parts from once it's warmed up?
    Can this correct a high idle condition? Should this be done when replacing the TPS?
    Thanks guys!
    There's no buisness like GO biusness
    Jul 2011
    quebec
    65
    From what i can tell it's to check for the operation of the fuel cut, I don't know why you would need to since the manual isn't very clear on what sensor you're checking.
    It wouldn't correct a high idle. Idle adjustments are made with the idle screw on the AAC valve (check EN-10 in the manual).
    If someone played with the throttle linkage like the previous owner did on my car. I had an idle of 2000rpm and adjusting the linkage fixed it for me.
    You would not need to do the steps on 8.1 when replacing a tps because the test makes you bypass the signal.
    Feb 2012
    55
    Thanks. But the screw on the aac valve is all the way in. The linkages were set as described in the manual.Code 55 is all I get.Must have something to do with Air Cond, lots of testing can be done there, as per the manual on EN237.
    Previous owner gummed up heater core with stop leak, so hoses are by-passing core, in a loop.
    Your help is appreciated.
  1. Is there a GTS-T manual out there R32?
    By clone in forum GTS Tech
    Last Post: 06-04-2011, 10:39 PM
  2. R35 GT-R Owners manual
    By klys in forum Nissan GT-R Tech
    Last Post: 12-16-2008, 04:40 AM
  3. GTR MANUAL FOR DOWNLOAD
    By GTRBOY in forum GT-R Tech
    Last Post: 02-23-2007, 04:17 PM
  4. Manual
    By -Jay- in forum GT-R Discussion
    Last Post: 02-19-2007, 08:02 PM
  5. Manual transmission oil
    By runningman in forum GTS Tech
    Last Post: 09-09-2006, 07:52 PM
