like adam said whats stock numbers for a gtr??
JZX90 & JZX81
http://i294.photobucket.com/albums/m...ersigdrift.jpg
Show me the conversion you are using to get that number please.Originally Posted by klys
Youre not reading...the gauge is in increments of KG/CM2...not bar.
1 kg-force/cm2 = 0.981 bar
(1kg/cm2)*(9.81N/kg)*(10000cm2/m2)/(100000N/m2/Bar)=0.981 Bar
yep the gauge is in kg/cm2
Marc-André
_________
2.2L RB20 GTS-T
So either the gauge was reading wrong or there is things done to the car that I'm not aware of?
Who knows...it doesnt matter, its blown.
What do people think of the GT2560R's as replacemnet turbo's?
wrong. the gauge is in millimeters of mercury per somethign or otherOriginally Posted by klys
Are you kidding???Originally Posted by cionide
anyhow, I know the measurement, its kg/cm2...stamped in there plain as day.
On another note a found the problem...the gauge was wrong and the dyno numbers are correct but who even knows how much boost I was running?? :roll: :roll: I sure as hell dont. Either way the motor was tired upon receiving it and that was fine since the plan was/is to build it this winter, so with the scads of boost, not enough fuel and a worn motor.....away she went. Oh well parked until next year...
Back the 12 sec neon for the summer :wink:
yes you are right.Originally Posted by cionide
the stock gtr boost gauge uses mm/hg plus and minus 700.
so 760 mm/hg is one atmosphere so 700 mm/hg is roughly 14 lbs
