Originally Posted by
dustyGTR
I understand what you are trying to accomplish and think I have a simpler solution. Use one relay for each set of lights (hook pin 30 to battery+ on each relay hook the pin 87's to each set of lights on each relay and ground both pin 86's) now you are left with the 85 trigger on each relay run the wire from your All Lamp Switch to one of the relays then run a jumper to the second relay pin85 but install a diode in the jumper ,then run a wire from your high beams also thru a diode to pin 85 of the second relay as a diode is an "electrical one way valve" when you turn on your high beams only one set of lights will go on since the power cannot flow back thru the diode to the second relay. The diode in the high beam trigger will stop power from feeding back to your regular high beams or circuitry when the All Lights Switch is turned on, Diodes are cheap and easily available , hope this helps.
Marcus
