Originally Posted by
Skym
Looks normal for the kilometres travelled. The flaking protective coating on the steering wheel is common at those km. Probably been under the sun alot in Japan.
In another 9,000kms, the cambelt, waterpump, auxilary belts, idler, tensioner bearings, etc need to be done. Usually done at 110,000kms.
Also the 100,000km service is needed, so change all of the fluids including powersteering, gearbox, diffhead, etc and change sparkplugs, fuelfilter, etc.
I would check the AFM for dirt, as some foam airfilters don't filter the incoming air properly, so dust could form inside the intake pipe that's behind AFM. Also the dust can be sucked into turbo and damage the compressor wheel.
If you do buy that car, clean the intake pipe, clean AFM and check for wear on edges of compressor wheel on turbo. Then replace podfilter with a Apexi podfilter.
