Is the rb25 turbo ball bearing or journal?
I have a Garrett 2860-5 forsale for 750 obo it will do 350-360 hp. it will bolt on and its internal wastegate.
I put a Garett GT2510 on mine that I bought for around $500 rebuilt. Straight bolt up manifold wise, ball bearing, steel wheels, but had to make custom lines. Wasn't too bad at all really. Let's just say after dyno runs last week I'm at around 350 rwhp. Great turbo that spools super quick and has massive response. Tops out quickly but gets you to the top FAST!!!!!
-Josh
1991 Mitsubishi Eclipse GSX
1990 Skyline GTS-R
Hey I'm not to sure if you have to change things but why Not use a holset
I have a r34 neo turbo, basically it bolts right in. I plan on gettin steel wheels and i heard since it is bein put on a rb20 the turbo will be able to safely boost 17+psi.
