Results 1 to 8 of 8
Thread: r32 pod filter heat shield?
    GTRCer overboostedlebaron's Avatar
    Jun 2009
    SARNIA ONTARIO
    241
    hey does anyone have the schematics to make a sheet metal or aluminum heat shield? i cant find anything on it
    frankiman's Avatar
    Apr 2009
    Montreal's south shore, Qc
    3,112
    schematic to make something custom ?!
    just get a thin (1/16) sheet of aluminum, bend, cut, drill, fit, think, you will be happy with your work
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    yeah just make it, it's not that hard.
    Jul 2008
    Alberta
    1,798
    make sure when you make it that you take a thick peice off foam that will seal the hot air from the engine bay getting to the pod filter. i think if they are made wrong that it can suck in just as much hot air through the top by the hood
    RixR32's Avatar
    Sep 2006
    Sarnia, Ont
    774
    I think I'm gonna go back to the OEm airbox with an aftermarket panel filter and see how it compares.
    My car performs noticeably different when evrything gets heat soaked in there on a hot day.
    I know the FMIC will make a big difference, but I'm sure suckin all that hot air can't be great. It still suprises me how hot these cars get under the hood.
    I worked on my wifes Mazda 3 and my car on the same day (oil change, changed headlight bulbs, etc..) and the wifes car was immensely cooler after about the same amount of driving.
    Just opening the hood on the Skyline damn near burns your hands....
    Rick
    '89 GTST - restored to near showroom (FOR SALE)
    '92 GTR - latest project, not far behind..already fresh engine!!
    '94 Mitsubishi Pajero Super Exceed 2.8TD LWB (my daily)
    '10 Mazda 3 Sport Hatch (wifey's)
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Quote Originally Posted by RixR32 View Post
    Rick
    exposed turbo.
    What I did is wrap my downpipe with DEI wraps, ceramic wrapped the turbine housing on the GT3071R and the engine bay temp dropped significantly.
    Da Nismo Kid Oakville's Avatar
    Sep 2007
    Oakville, Ontario
    4,467
    Mike you have any photos of the wrapped items?
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Panel filter + airbox is better when hood is down. HP result at wheels with airbox is usually alot higher than podfilter when bonnets down (there's a dynochart on internet somewhere showing this difference). Also on my car, felt like more hp down low (at least thats what I noticed). I only changed to podfilter, due to airbox clipping points failed and couldn't hold 2x pieces of airbox together (common problem) and podfilter was cheaper. If I could fix airbox, would refit airbox to car.
    With podfilter, boost can rise 0.1bar, 8rwkw x 1.341 = 10.728rwhp with bonnet up, so that's the benefit of a podfilter.
  1. exhaust heat shield
    By illmatic_1 in forum GT-R Discussion
    Last Post: 02-25-2009, 01:03 PM
  2. SFI Flywheel shield
    By speedfreak in forum General Skyline Tech
    Last Post: 02-18-2009, 07:56 AM
