Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Rb25 no compression in any cylinders
    GTRCer nardocrew's Avatar
    Aug 2010
    Vernon, B.C.
    45
    I just recently did a rb25 swap into my r32, I cannot get the car to start, turns out there's no compression in any of the cylinders, there's spark, fuel and the engine spins, I purchased the motor from a reliable seller who says they tested the compression and replaced the timing belt and all was good.
    I didn't mess around with the timing or remove the cams so I don't believe there is any possible way I could have bent the valves, let alone all of them. the only thing I did mess around with while trying to get it started is the cas, is it possible that's the cause of no compression? and if not does anyone have an idea what else could be causing the problem? I have yet to pull the head off to check the valves.... Also its a series 2 rb25 and it has hydraulic valves
    Any help would be greatly appreciated
    Thanks
    Aug 2010
    Vernon, B.C.
    45
    I tried it throttle open and closed, i have yet to pull the head off but I pulled the valve covers off and the exhaust valves are all stuck open slightly and all the intake valves are closed and in perfect condition, all the valves move, cams spin and its all timed correctly. Is it a common thing for an engine thats been sitting for 6 months or w.e it is to have valves stick for any possible reason, I want to leave pulling the head as my last resort assuming the exhaust valves are bent...
    Thanks alot for your help
    GTRCer BrianV8's Avatar
    Aug 2008
    Kamloops
    2,051
    i would double check the timing on the cams, could be out
    GTRCer Brendan's Avatar
    Jun 2007
    Cambridge, ON
    376
    My money is on the exhaust valves being bent. They don't really get stuck open for any other reason.
    Brendan : Union Autoclub
    '01 Audi A4 quattro - daily
    '90 240SX Coupe - RB25
    I had a Skyline once.
    Jul 2010
    Yokohama
    17
    This happened to me when the timing belt on a 4ag skipped three teeth after being installed correctly.
    You say the timing is correct however.
    The sound of zero compression still rings in my memory.
    How about pictures of the exhaust valves stuck open. I really can't see why all of them would be left open.
    Hmmm. The series two engine has a variable cam timing system... Just thinking...
    Pics?
    Living the dream in Japan
    Jun 2007
    Cambridge, ON
    376
    It's only the intake cam that's variable so that wouldn't really apply to this situation.
    Aug 2010
    Vernon, B.C.
    45
    Ill definitely take some pictures tomorrow after work and throw them up, Im going to try a new technique tomorrow to push the valves up and see if it does anything at all, if not im just going to resort to pulling the head off...
    Thanks a lot I might even take a video of the cams and valves when its turning over and throw it on youtube so you can see whats going on
    Aug 2010
    Vernon, B.C.
    45
    Intake cam valves fully closed.
    Exhaust cam valves stuck open slightly.
    And a couple videos of cams and valves while turning the car over...
    Intake cam
    Exhaust cam
    GTRCer Rblove26's Avatar
    Mar 2010
    Pembroke
    114
    Another easy and good way to tell just about exactly whats going on in the cylinders is to just do a cylinder leakage test. you gotta check each cylinder one at a time by just bringing them up to TDC (so both valves are closed) and applying shop air. you'll need an adapter that threads into the spark plug hole and fits on the end of a air line. if you are loosing compression you'll find it by just listening
    air coming out intake = bent intake valve
    air out exhast = bent exhaust valve
    also could be timing...but you'll just have to double check it
    pull the dipstick and oil cap to check = means the rings arent any good (or pistons etc)
    anyway if there is a leak you can find it this way and at least give the source
    good luck
    Turbos. The replacement for displacement!
    Jun 2010
    Edmonton
    86
    This exact same thing happend to me. I bought a rb25 swap and motor was garbage when it arrived(lets not name the engine supplierlol)
    so I sent it back and demaned a refund. How many kms did they say were on this motor? the usual 25-60 thousand ??? lol lies
  1. WTB 30PSI of compression for 2 cylinders!
    By Bruizer in forum Sponsor Forums
    Last Post: 06-23-2008, 12:44 AM
  2. need help !! running on 5 cylinders , i think ..
    By QC89GTST in forum GTS Tech
    Last Post: 08-23-2007, 01:25 PM
  3. rb25 compression test
    By dkfaiosantos in forum GTS Discussion
    Last Post: 08-04-2007, 10:18 AM
  4. RB25DET running on 4 cylinders
    By judasentinel in forum GTS Tech
    Last Post: 07-27-2007, 12:02 AM
  5. Pieces of my FMIC in my cylinders...(?)
    By DrMango in forum GTS Tech
    Last Post: 03-25-2006, 03:07 AM
