has anyone seen this intake manifold before? is it good? it seems like a good deal and i cant find a intake manifold for the rb20det anywhere!!
http://nozzs.com/index.php?main_page...products_id=13
The shape of intake plenum is good. Just make sure flange is straight by checking, skimming if necessary.
Gibson GTS-R with RB20DET used stock intake manifold with custom intakepiping -
http://www.youtube.com/watch?v=8_iHWWiVBXs
Front mount intake plenum is not worth it, unless your engine is producing over 500hp.
hey rabbit, its just in the stock position on the left side. why?
hey skym, so your saying i shouldnt get the aftermarket manifold? and just try to shorten the piping?
Just saying it's not worth it unless your building car for a certain application, where intake manifold needs to be changed / modified. Usually over 500hp at engine or applications mentioned below.
Shorter runners on intake manifold should give more mid to topend hp (dragstrip, racetrack).
Longer runners on intake manifold should give more low to mid (street, racetrack).
Opposite on exhaust side where longer runner is mid to top and short runner is low to mid.
You can buy Blitz, etc intercoolers that have intake piping which returns to stock location. They use Blitz intercoolers on GTS-R conversions (RB20DET) on R31, where intake piping returns from intercooler to side where stock SMIC (Side Mount InterCooler) was.
For example with Blitz intercooler that returns to side where SMIC was -
http://justjap.com/store/images/P/blitzserfkit-01.jpg
R31 GTS-R (RB20DET) at factory had similar style of return type intercooler.
The racecar (R31 GTS-R) version of intakepiping in post above was to remove the 90degree bend (restriction) when it returns from intercooler to side where SMIC was and stop intakepiping getting heatsoaked by (the reason behind why they wrapped the intakepiping) running intakepiping just behind radiator with R32GTR style of intercooler.
