Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Gts upgrade list?
    Sep 2010
    Gatineau
    24
    Gts upgrade list?
    I've used the search button and searched the old fashion way, but i can't seem to be able to find a list of upgrades and they're ( I believe) approximate cost for the GTS. I found one in the general FAQ section, only it was for GTR's, can the same list be used for GTS's?
    If not, anyone have aprox prices for minor upgrades?
    If it helps, I would be aiming for around 300-350 HP.
    Jul 2007
    calgary
    466
    350HP will be expensive, theres no way around it. 300hp would be a little more achieveable because it can be done easier with stock manifolds because thats where the price really starts to add up.
    Intake - $150
    Exhaust - $600-$1000
    Boost controller - $50 - $500
    Injectors - $400
    Turbo - $1500 - $2000
    Tune - $$$$
    These are rough numbers that I found with a little research, by no means will it be exactly this.
    Jesse
    1990 HCR32
    2006 Chev Silverado
    GTRCer supguyex's Avatar
    Apr 2008
    Vancouver
    1,570
    for safety sake it might be worth it to toss on a metal headgasket and some set of upgraded headstuds.. and since you have the head off get it cleaned up and ported slightly... the tune is super crazy important tho. Also a boost gauge would be something worth getting as well.. but a lot of skylines came with these anyways
    widebody rb25 r32
    friends of:
    genetic tuning!!!
    Quote Originally Posted by Muss View Post
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    intake: $50.
    exhaust: $600-700 (get a decent downpipe that wont crack. ebay testpipe and catback)
    intercooler: $200-600
    boost controller: $50-350
    nistune: $???
    done. quit while you're ahead. :P
    Sep 2010
    Gatineau
    24
    Well I'm planning on getting one in a few years, so i'd have time to save up and figure it all out, I'm asking the approximate prices to see what one (between GTR and GTS-4) would be better/efficient for what I want out of it, lol.
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Basic boost up menu for stock RB20DET turbo, 330hp at engine at 1bar / 14.5psi (high boost setting) -
    FMIC (HDI or similar size tube N fin intercooler)
    3" dump / front pipe, high flow cat, catback exhaust. (X Force, bolts on)
    550cc injectors (Deatchwerks injectors)
    255lph fuelpump (Bosch intank 040 300lph, Nismo 255lph fuelpump kit, Walbro 255lph). You'll need new seal for fuelpump housing, etc from Nissan, if you don't buy Nismo fuelpump that is shipped with new seals, etc.
    Z32 MAF + Z32 MAF plug / tail (needs to be wired into MAF loom)
    NGK PFR6A or PFR7A sparkplugs, depending on how lean engine is going to run or hp level your going to run every day with 0.8mm gap. (or similar copper sparkplugs). Let ECU tuner work this one out.
    Boost controller (dual solenoid Bitz or HKS boost controller)
    1.2mm, 80.5 bore Tomei metal headgasket, ARP headstuds
    Nismo single plate clutch with light weight flywheel or upgraded disc, pressure plate with stock flywheel.
    Nistune modified stock ECU
    Then need brake pads, brake fluid, braided lines, brake stopper (minimum, front brake pad upgrade, brake fluid upgrade, which is at least Super DOT 4 with 600+ boiling point), suspension, rims / tyres to match the hp engine is going to produce.
    Then can add Tomei Poncams, 18rwkw (24hp) at same boost level or get factory cams reground to Poncam specs, which cost's around half the cost of new cams with new Tomei valve springs to match, as factory valve springs probably have done high km and need to be replaced. Best to do valvesprings at same time as metal headgasket and can change cams later on.
    With cams, should produce around 354hp at engine at 1bar (high boost setting) or above 300hp at engine for everyday use on low boost setting.
    Also rubber intake pipe infront of turbo might collapse at 1bar, so might need to replace with metal intake pipe.
    Above is if engine is in good condition (do a dry, wet compression test before doing any mods) and running good gas. Octane of gas, ECU tune to match plays a role in above hp figures, so could be less or more.
    With GTR, more like 430ps at engine with stock cams (similar basic boost up menu, except has upgraded sump baffles, etc), stock turbo's or more hp with cams. But similar boosted up R32 GTS-T is lighter, so can give a 200kg or so heavier GTR good competition for less $$ spent. Look at R32 GTS-T in Targa Tasmania if you don't believe me, where a stockish boosted up R32 GTS-T can out pace a stockish R35GTR, R32GTR. R32 GTS-T is similar to a EVO in terms of times in Targa.
    Sep 2010
    Gatineau
    24
    Lol, after that post, I do believe I have some research to do.
    Thank you for all the info.
    The only thing I couldn't figure out/find information on is the "1 bar" thing in regards to the boost, a little help? ( sorry if its newb question, I'm trying to learn :P )
    GTRCer Saskacer's Avatar
    Feb 2008
    Saskatchwan
    168
    1 bar is basically 'around' 14 psi. Stock rb20's run 10psi. I believe 1 bar (aka 14psi) is the max that you will want to run on the stock rb20 turbo. Please feel free to add/correct me.
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Quote Originally Posted by DreadedFist View Post
    intake: $50.
    nistune: $???
    where's all the supporting mods?
    May 2005
    1,667
    Quote Originally Posted by M13 View Post
    Hey i don't plan anything car related, I just randomly buy stuff that I think is neat or will make the car better
    It's a terrible way to do things, no one do it.
  1. GTR Only Msn List
    By PH_Motorsports in forum GT-R Discussion
    Last Post: 03-29-2012, 05:23 PM
  2. My $16,000 upgrade list, Looks ok??
    By jeremyboddy in forum GTS Discussion
    Last Post: 09-02-2007, 07:15 PM
  3. Why don't you list out your location!?!?
    By Maverick in forum GTRC OT Pit
    Last Post: 04-25-2007, 04:55 PM
  4. 2 New Problems to Add to the Sh!t List
    By turbo_steve in forum GTS Tech
    Last Post: 11-12-2005, 11:49 AM
  5. Progress list
    By Gaelen in forum GTS Tech
    Last Post: 09-24-2005, 06:19 PM
