Results 1 to 9 of 9
Thread: r32 with sum mods can it be tuned with stock ecu
    GTRCer nickdutch's Avatar
    Oct 2010
    vic bc
    185
    hey i have a gtst r32 with a biger maf and biger injecters 3in doun pipe and exost and biger intercooler and intake and a rb 25 turbo at 14 psi can i run this all well with my stock ecu or do i need nistune or what would be best to run all this
    Oct 2010
    vic bc
    185
    its a z32maf and i have yelowe jaket coil packs and a walbero fuel pump
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Nistune converts stock R32 ECU, so it's like a stock ECU in R35GTR, where it can be reflashed by consult port that's located under dash on drivers side. But Nistune does it in realtime, so change figure in cell on ignition map (on laptop), engine responds straight away to the change. Nistune requires consult cable (connects laptop to car), Nistune tuning software, laptop, wideband (connects to laptop).
    GTRCer johnnyjohnny's Avatar
    Jan 2010
    Oakville, ON
    378
    Nistune also requires a hardware "daughterboard" to be installed in the ECU....
    '93 R33 Gts25T Inked Art Car - SOLD
    at www.inkedartcars.com
    GTRCer aN4rk1's Avatar
    May 2010
    Mississauga
    1,042
    You best bet is probably to get a powerFC and use that. Its a lot more powerful then Nistune, and you have a spare stock ECU incase anything goes wrong.
    By the time you get your ECU "Nistuned" you will have spent almost as much as a used powerFC. You dont NEED a hand commander but its nice to have one.
    Also dude....:
    - sum
    - biger
    - injecters
    - doun
    - exost
    - yelowe
    - walbero
    Please for the love of god, spell properly....
    GTRCer whiteboy87's Avatar
    May 2008
    calgary
    387
    just get your stock ecu chipped and retuned. it is by far the cheapest and easiest. a power fc is very expensive for the rb20 and hard to find, plus unless you know what your doing with it there is no point. alot of very powerful skylines just have a chipped ecu for their tune.
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    Quote Originally Posted by aN4rk1 View Post
    Also dude....:
    - sum
    - biger
    - injecters
    - doun
    - exost
    - yelowe
    - walbero
    Please for the love of god, get your sources right.
    How much do you think Nistune is? Also if you tune with Power FC, your stock ECU won't be useful for when "things go wrong" as it can't run the mods he mentioned.
    I think you are just running off on assumption on your thoughts on Nistune.
    GTRCer R33rr's Avatar
    Aug 2009
    604_LITLAN
    509
    dude pm shadybeaverguy he would help you on chipping
    A BIRD ON YOUR HAND ** **** ON YOUR WRIST
    Sep 2007
    South
    6,702
    Johnnyjohnny, good point about the daughterboard, thanks.
    Chipping stock ECU is good if your not going to modify the engine past the mods you have listed.
    From what I understand, PowerFC is faster than stock R32 ECU, because it has onboard boost control (same processor speed, etc as stock R33, R34 ECU with onboard boost control, etc). R32 ECU doesn't have onboard boost control, so it doesn't need the extra processor speed, etc to run multiple things at same time. R32 ECU processor speed is faster than engine, so enough for most applications, even up to 1100hp.
  1. wtb:stock ecu or tuned ecu
    By white_gtst in forum Want to Buy
    Last Post: 07-14-2008, 06:35 PM
  2. Thank you mods!
    By Cory Scheuer in forum GT-R Discussion
    Last Post: 03-30-2006, 01:21 AM
  3. BEST MODS FOR r32 gts
    By banshee 101 in forum GTS Tech
    Last Post: 01-21-2006, 03:59 PM
  4. Replies: 5
    Last Post: 08-14-2005, 11:50 AM
  5. doing own mods
    By sleeper in forum General Skyline Discussion
    Last Post: 02-07-2005, 11:58 AM
