Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: boost drop
    GTRCer nickdutch's Avatar
    Oct 2010
    vic bc
    185
    boost drop
    i just dynod my r32 gtst and i got 235whp and 232 torque it was runing 14psi but then the boost starts to decreas slowely at 3500rpm and gose doun to 10.5 psi at 5500 rpm whare ime makeing the power i have a rb25 turbo i am just woundering why it drops to 10.5 can the turbo just not keap up or is my waset gate leting go? ime runing a boost control tee and hks mushroom intake yelowe jaket coil packs full 3inch apexi exost and the rb25 turbo and a good aftermarket fuel pump and gtr injecters
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,054
    what year is your gts-t?... isnt 230hp less then what the gts had out of the factory?? lol
    GTRCer quadracer111's Avatar
    Dec 2009
    Martensville, SK
    967
    ^^ r32 gts-t's had 215 or 216whp from the factory.
    Oct 2010
    vic bc
    185
    its a 91 r32
    Jun 2009
    Coquitlam, BC
    303
    My manual boost controller is set to like 15psi but it settles at 13.5 or so from what I remember when I had it dyno'd. Dunno if that would be your problem or not since it's a pretty big drop?
    Sideways is the best ways.
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    Quote Originally Posted by quadracer111 View Post
    Actually, it had around 180whp from what i have heard. I believe the stock RB20 is something like 210 crank based on factory spec?
    At any rate, that is a pretty hefty drop in pressure.
    1 Thing to look at is your manifold pressure on your dyno chart. From this you can see where the boost is seeping off..
    You'll see one of 2 common things;
    1. sporadic spiking; high frequency of up and down curves of various pressures
    2. a very gradual slope decreasing in boost pressure
    The former is often due to a turbo being pushed to its maximum potential, and by the looks of your hp numbers, that's highly unlikely.
    The latter is often due to, from what im told, a TIRED turbo. If the boost creep is enough to exceed 2 psi and your slope takes a pretty nasty tumble at the end of your curve, it's could very well be a leaky seal. CFM's increase as a function of RPM, as more exhaust gas passes through the exhaust turbine, the faster the turbo spools, if oil is being pushed from the bearing cavity, you're going to increase heat, and oil will cause a disturbance in air circulation and pressure, slowing the turbine.
    Of course this is your worst case scenario, and i surely hope you've noticed if your car is eating that much oil..
    Otherwise you may have a small leak somewhere.. ? lol.
    It could be as simple as a tear in a gasket, that after a certain rpm begins to seep.
    Check for symptoms of oil leaks or a on-the-outs turbo, and do a boost leak check.
    Also, what kind of boost controller? If its electronic and not properly set up, maybe your "caution" values are set too low and your bouncing off that.. Pretty honest mistake, if you neglect to read manuals :P
    Oct 2010
    vic bc
    185
    hmm ya ime not loosing eny oil and its just a stedy drop in presher no big drop as soon as it peaks at 14 at 3000rpm it starts slowely going doun but the hp is still going up at the same rate
    Aug 2010
    Courtenay , BC
    1,054
    Quote Originally Posted by nelsonmxmarc View Post
    hey if you guys have user manuals, post em up!
    user manuals
    A. Nash
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Reasons why boost level drops -
    1.) Turbo out of puff (as mentioned above)
    2.) Lean A/F ratio
    3.) Leaking BOV
    4.) Stuffed stock internal wastegate actuator (usually hear rattling sound on back of turbo, as spring inside bulb has failed)
    5.) Intake airleak (as mentioned above)
    Most common one with mild mods is leaking stock BOV, especially when engine has a bigger turbo installed. It leaks after 10psi. Blocking hole (boost feed, helps BOV to release properly at lower boost levels) next to main valve on bottom of BOV is a temporary solution, but it makes a flutter/surge sound (flutter/surge sound from podfilter). After fitting a proper aftermarket BOV (Synapse BOV), I wouldn't recommend the stock BOV mod.
    Oct 2010
    vic bc
    185
    hmm could be my bov it is apexi but i got it with the car and it looks kinda old and it spuders sum times insted of a solid blowe off
  1. Drop cams into head with no adjustment?
    By Touring240 in forum GT-R Tech
    Last Post: 02-12-2007, 02:07 PM
  2. HELP: Car feels like there is a drop off at 5500 rpms
    By skyline_guy777 in forum GTS Tech
    Last Post: 10-26-2006, 09:45 AM
  3. Voltage drop???
    By nbskyline in forum GTS Tech
    Last Post: 09-01-2006, 10:34 PM
  4. FS 90 Skyline GTR -price drop-
    By da_prince in forum Parts for Sale
    Last Post: 08-12-2006, 03:06 AM
  5. RB20 Turbo *price drop*
    By nismo-ya in forum Parts for Sale
    Last Post: 02-02-2006, 09:12 PM
