Im looking to increase the lock in my r32 as well, Im keen on doing a few things in my front suspension to make my car a little more track worthly.
First off does anyone have experience running a big front sway bar? I have a fair size rear one 22mm i believe but I will be runnning a 24mm whiteline unit and im worried I may lose some of my oversteering characteristics, Well i guess thats a given but will it go to far the other way and Ill have lots of understeer? Maybe some toe out will help me.
As for the lock im most likely going to install some spacers at very least, but how much spacer can my stock inner tierods handle? Is 5mm ok? As well as this Ill probably grind some of my bump stop off but im worried i may start over centering the steering wheel, and/or rubbing the wheel on the inside of the wheel arch.
I also considered aftermarket tierod ends but im not sure if these are all the effective, theres a lot of hype about less bump steer and what not.
Boxing control arms worth it?
I know some of you are talking about running s13 front ends which is cool but a little extreme for me.
Someone please start a gtrc drifting setup chat with me
LinkBack URL
About LinkBacks
