Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Rear Tire drag spin on sharp turn normal?
    Feb 2011
    Guelph Ontario
    10
    Hey, I have done quite a bit of work to my R32 GTS-T in the past week. I just got it and did full exhaust and new brakes/rotars, also installed new rear tie rods. However there is something I am worried about perhaps was the reason for the tie rods wearing out. But when I turn sharp with this car the rear wheels skip or spin when i turn sharp. is there adjustment on the LSD or should I just let it drag the outside or spin the inside tire? It seems like it can lay a legit patch of rubber this way and i don't mind it if you guys think it will last after all I do want to upgrade the intercooler and max out my turbo to full potential and having the rear tires in such a locked position would lead to amazing looking tire smoke.
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,162
    Sounds like you diff is welded to me.
    92 Gtst/Silver bullet
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,054
    Quote Originally Posted by BradicaL View Post
    mine does the exact same thing.. i figured it was normal?
    Quote Originally Posted by Supraclean View Post
    whats the purpose of doing that?
    A. Nash
    GTRCer evilgtr's Avatar
    Jun 2009
    Moose Jaw Saskatchewan
    837
    Yea welded or you have a full spool someone put in for drifting.
    The purpose of doing that is so both tires light up when you want them to,every single time. Perfect for drifters but a huge pain in the ass if you like just cruising around and driving around town
    GTRCer S13Jordie's Avatar
    May 2010
    Brockville
    305
    Since he just said it happens on sharp turns, that could mean that you could have just found out that your car has a 2 way. in that case, thumbs up
    Jun 2009
    837
    ^ you won't notice a welded Diff or full/mini spool driving straigh = tires turning same speed, even turning softly it's hard to notice. I had a welded diff in my commodore when I lived in Australia it was a blast !
    May 2008
    Hanover/Kitchener
    277
    its caused because in a turn the inner tire should turn a little faster on a regular diff but on a 2 way or welded diff the clutch packs do not dissingage the inner wheel to allow it to move faster so you end up spinning the inner to make up for it not covering as much distance
    May 2010
    Brockville
    305
    Quote Originally Posted by derbeck View Post
    its caused because in a turn the inner tire should turn a little SLOWER on a regular diff but on a 2 way or welded diff the clutch packs do not dissingage the inner wheel to allow it to move Slower so you end up spinning the inner to make up for it not covering as much distance
    The outer wheel must spin faster bc it has more ground to cover.
    May 2008
    Fort Erie
    764
    Sounds like a 2 way Loose Sock Drifter.
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    At least you can get both wheels spinning. My stock vlsd is worn out and just single spins no matter what.
  1. car stalls after spin out?
    By Madskyline in forum GTS Tech
    Last Post: 01-04-2011, 05:48 PM
  2. Inner Rear Tire Wear?
    By Joker in forum GT-R Tech
    Last Post: 03-10-2010, 10:58 AM
  3. How do you spin bearings?
    By stucknot in forum GT-R Discussion
    Last Post: 04-02-2008, 10:02 PM
  4. wtb-drift spin nob
    By TK-GTS in forum Want to Buy
    Last Post: 01-30-2008, 07:43 AM
  5. FS: Essential Triple Gauge Pod *Very Sharp!*
    By FITZY_07 in forum Parts for Sale
    Last Post: 11-17-2007, 10:48 PM
