Results 1 to 7 of 7
Thread: 2nd fuel pressure regulator?
    Jan 2008
    Fonthill Ont. Canada
    236
    At the back of the engine I was hooking up a turbo coolant line and noticed a vacuum line just hanging. It was cracked and had fallen off. It started at the plenum and was supposed to be hooked up to what looks like a fpr on the rear of the fuel rail. Are there two. I just changed the one on the front and am wondering what this is?
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,054
    i know what your talking about but i have no idea. i would like to know too
    A. Nash
    Jan 2008
    236
    I just had a quick look on Fast and I could not identify it either. Come on, somebody has got to know what this is.
    May 2008
    Fort Erie
    764
    I believe its the Fuel Pressure Damper. Dampins the pulses in fuel flow coming from the Fuel pump.
    Yep, just checked Fast. Damper Assy - Fuel. Section 164
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    That's what I thought as well. But FPR on back of engine is a damper that cancels out the pulses that reverse direction inside fuelrail due to FPR on return part of fuel rail (front of engine) creating a pulse that reverses direction.
    When running 2x pumps into a fuelrail (one on each end of fuelrail), the fuel coming together in the middle of fuel rail (where it exits) acts like a damper.
    At least that's how I understand how it works from what someone told me.
    May 2008
    Fort Erie
    764
    Ahh, interesting. Never thought about that. I also noticed in Fast that the damper only came on RB20det after 91/08. If i interpreted it correctly.
    Jan 2008
    236
    Thanks for the info everyone. I will check fast again just out of curiosity since I could not find it first time around.
  1. vacuum hose on fuel pressure regulator
    By markc32 in forum GT-R Tech
    Last Post: 08-31-2010, 08:07 PM
  2. Fuel pressure regulator Q?
    By Gts_Junior in forum GTS Tech
    Last Post: 06-08-2008, 06:05 PM
  3. adjustable fuel pressure regulator FPR
    By minispeed in forum GT-R Tech
    Last Post: 09-27-2007, 10:18 AM
  4. WTB: Fuel pressure regulator and 255 fuel pump for rb20det
    By skyline_guy777 in forum Parts for Sale
    Last Post: 10-31-2006, 03:21 PM
  5. FS: Nismo R-Tune Fuel Pressure Regulator (USED)
    By felix yuen in forum Parts for Sale
    Last Post: 05-02-2006, 05:14 AM
