So I found a bunch of 300ZX N/A clutch parts online to slap onto my RB20DET, and it says in the descriptions that the flywheels shouldn't be machined when replacing the clutch assemblies. Is this a 300ZX thing or are they just totally full of crap?
Seems like for best performance you should resurface the fly wheel anyways.
no reason not to resurface the stock flywheel unless its out of spec. You just dont want to try and machine an aftermarket 2pc one.
Resurfacing is fine. Machining can cause serious problems. check this video...
http://www.youtube.com/watch?v=n0TxZFDLa3w
Thats an example of a oem flywheel machined too much, they are known to just blowup. Not sure how much you can shave an oem skyline flywheel safely but I would recommend spending the money on a aftermarket one and potenitally save yourself from a gernade beside your legs.hope that helps.
damn!! Guy in the CRX is lucky that the pieces of flywheel didn't end up hitting him.
10 Infiniti FX35
09 Infiniti G37X coupe
02 Subaru WRX....sold
01 VW jetta 1.8T....sold
90-00-08 BNR32
92 NX2000...sold
95 S14 LE...Sold
there is nothing wrong with machining a flywheel, having said that i would not do it more than once on a stock flywheel if your doing a high hp application
I agree about heavily machining to make stock flywheel lighter. It makes it weaker.
i just had mine resurfaced when i tore my engine out to clean it up, it was kinda scuffed up. no ridges or anything, so i thought it'd be alright. I won't be shooting for over 400HP until I get a new clutch, I'll get a new flywheel when I do that.
