Results 1 to 2 of 2
Thread: Hey I put a top mount turbo need help with lines
    GTRCer vincegts's Avatar
    May 2009
    king city
    53
    Unhappy Hey I put a top mount turbo need help with lines
    Where should I run the Coolent lines from then original turbo and the top oil cooler is a different type of line pls help
    Supraclean's Avatar
    Jun 2009
    Grande Prairie
    1,162
    Take ur turbo to your local Hydraulic shop for the proper fittings. They should be able to give you options. Once you have your fittings measure/map out how you want your lines run. Go back to them and they should be able to make you custom ones.
    If not find your measurements and fittings and can order from places online like Mopac/earls/. Atpturbo stuff like that.
    Best of luck.
    92 Gtst/Silver bullet
  1. Turbo Oil Lines
    By MacAttack in forum GTS Discussion
    Last Post: 06-02-2011, 09:04 PM
  2. Turbo Lines/ routing
    By mattk in forum GTS Tech
    Last Post: 03-14-2011, 05:23 PM
  3. turbo oil and coolant lines
    By ruthere in forum Want to Buy
    Last Post: 09-06-2010, 11:52 PM
  4. WTB: Turbo lines
    By Fathom in forum Want to Buy
    Last Post: 06-13-2008, 08:38 PM
  5. WTB: RB26DETT turbo oil lines!!!
    By driftking in forum Want to Buy
    Last Post: 12-01-2007, 05:13 PM
