Results 1 to 6 of 6
Thread: Cracked block????????
    GTRCer MacAttack's Avatar
    Apr 2011
    Aldergrove
    43
    What would be the chances if you blew a head gasket and it over heated... Could the block crack? let me know ur thoughts.
    GTRCer clone's Avatar
    Aug 2010
    Caledon
    226
    hope that didn't happen to you. RB26 is pretty strong. but I'd go crazy with a leek test,wet test, compression test. there are some good how too videos on utube.
    also if you have any buddys with those new camera's that can go in the block.
    GTRCer bobbo's Avatar
    Aug 2009
    Halifax Nova Scotia
    1,011
    I doubt it. A cracked block normally occurs from freezing or inside parts trying to get out.
    GTR-Dad's Avatar
    Dec 2005
    Beaumont, AB
    2,955
    I'd be surprised to hear that a block cracked from overheating. Having said that, overheating isn't great for the fit between the block and the head and the block.
    Do you see symptoms of a problem or just wonder?
    The Beaumont Connection
    GTRCer bellis_GTR's Avatar
    Jan 2010
    London, ON
    1,573
    Your head is more likely to crack then block since the head is aluminum. Your HG could be perfectly okay, but you may have put a wee crack in between the water jackets and chamber.
    Exactly what was wrong with my car.
    Apr 2011
    Aldergrove
    43
    i got my head pressure tested, resurfaced and new valve seals put in. cometic gaskets all around and arp headstuds, still the coolant leak persists and idle drops and car stalls when thermostat opens
  1. 05U Block
    By newalliance123 in forum GT-R Tech
    Last Post: 01-02-2011, 09:39 PM
  2. rb26 block or short block
    By zedd in forum Want to Buy
    Last Post: 06-26-2008, 10:39 PM
  3. Best way to fix a cracked/split bumper?
    By Chris_RB in forum General Skyline Tech
    Last Post: 04-08-2008, 01:01 AM
  4. cracked bumper or side skirts ?? check this out...
    By NISMONEWF in forum General Skyline Discussion
    Last Post: 03-21-2007, 01:56 AM
  5. WTB 25 or 20 block
    By mini_me1209 in forum Parts for Sale
    Last Post: 06-27-2006, 02:38 AM
