Results 1 to 7 of 7
Thread: Sheet, what is wrong here?
    GTRCer m_melen's Avatar
    Nov 2008
    The Great State of Texas
    1,779
    Oh boy, not sure what's going on here. So I tried to put the slave cylinder on the tranny, doesn't fit. I can't get it close enough to the bolt holes. Tried letting the fluid out through the bleeder but it doesn't compress or anything. The pic of just the tranny shows me holding the bracket as far forward as it will go by hand. What have I done wrong here?
    GTRCer amnash's Avatar
    Aug 2010
    Courtenay , BC
    1,055
    its supposed to compress thats all. and should be pretty easy to move, even with fluid in the lines. how longs have it been off the car? maybe its seized?
    A. Nash
    Nov 2008
    1,779
    Do I have to pry on the fork or something? It doesn't have much travel when wiggling it by hand
    Nov 2008
    1,779
    The slave cylinder should compress? Its been off for like 2 years lol
    I never disconnected it from the line, just removed it from the tranny
    Aug 2010
    Courtenay , BC
    1,055
    you wont compress the fork by hand thats the slave cylinders job. that little nubbin part of the slave that pushes agains the fork should it move in and out of the cylinder. when you press the pedal it pushes the nubbin thing agains the fork and ur clutch moves.
    it should slide in and out by hand man. take the boot off, have a look. if it looks all rusty and sheet just get another one.
    do some research on what cars are compatible. i think a nissan pathfinder has the same one but not 100% sure about that
    A. Nash
    Nov 2008
    1,779
    Doooood you were 100% right! I pulled off the boot and it was all nasty inside and seized. But using my mighty Texan muscles I pushed in the piston with a screwdriver and freed it and now it moves nicely. Fit right onto the tranny.
    You're the best.
    Aug 2010
    Courtenay , BC
    1,055
    sweet glad it was an easy fix
    A. Nash
  1. Suspension build sheet
    By maverick2 in forum GTS Tech
    Last Post: 03-19-2008, 12:02 AM
  2. wrong fluid at the wrong place
    By mbskyline in forum GT-R Tech
    Last Post: 04-13-2007, 02:26 AM
  3. Auction sheet question
    By Stinky_1 in forum General Skyline Discussion
    Last Post: 02-26-2007, 12:12 AM
  4. Auction Sheet - T
    By Lotus97 in forum The Auction Block
    Last Post: 02-15-2007, 12:51 AM
  5. auction sheet translation
    By edmboi in forum GTS Discussion
    Last Post: 06-19-2006, 02:38 PM
