Results 1 to 8 of 8
Thread: lower
    May 2010
    winnipeg manitoba
    4
    lower
    hello all i have a pretty stupid question to ask but i have run out of options...im kinda new to the whole customizing my car thing and i need some help..i have a 90 gtst type m mainly stock except a few minor upgrades like the exhaust,intake, turbo timer...gauges **** like that..what i want to know is what do i need to lower it...im a weekend cruiser not a racer so im kinda lookin for the easiest way to do this...parts and prices and maybe a location to buy these parts will be awsome..thanks
    Aug 2008
    Edmonton
    347
    You could buy some coilovers or cut your springs a bit.
    Regards,
    Ken.
    Dec 2008
    GTA
    440
    Find a used set of coilovers
    They are springs an struts together that can be adjusted in height up or down and also dampening stiffness.
    Do not cut your springs. Dangerous and ride quality is ****
    Or you could get springs and keep your stock struts
    Atleast a 1.5 to 2" drop
    Jan 2006
    Winnipeg
    108
    Give Adam at Feast Auto a call (location Japan). He can source you coilovers or lowering springs. There is a nice set of HKS springs on Japanese Yahoo, you can get Adam to bid for you.
    HCR32 HKS Springs - http://page3.auctions.yahoo.co.jp/jp/auction/c298535043
    Adam Feast Auto - info@feastautoexport.com
    Jan 2006
    Winnipeg
    108
    Quote Originally Posted by r33_gtst View Post
    Yes, please do not cut springs..
    Stay within the 1"-1.5" drop range, or you'll have to play around with other suspension parts.
    Da Nismo Kid Oakville's Avatar
    Sep 2007
    Oakville, Ontario
    4,467
    Yes, a set of aftermarket coilovers is the easiest way to do it. Usually from 500-1000 for used, depending on what you get. Depending on how low you want to go, you may have to look into rolling your fenders/removing fender liners.
    GTRCer nelsonmxmarc's Avatar
    Jul 2009
    Montreal
    2,039
    a LOT of people dont account for this, but your toe will be off considerably. Running positive toe in the rear or front \ ^ / is not safe. So make sure you get an alignment. IMHO, only do this if you plan to get adjustable components - Upper control arms and front castor arms.. Tire wear and overall drivability is greatly affected, even with a minimal drop.
    www.nelsonmx.wordpress.com
    GTRCer Nismo_line's Avatar
    Nov 2009
    204
    1,501
    if you drop it a little bit and get a alignment you will be fine. i did this, got a alignment and i dont have adjustable control arms. my toe is bang on, same with camber
  1. Lower Contol Arm
    By Like_A_Sum_Bootay in forum GTS Tech
    Last Post: 03-27-2011, 01:21 AM
  2. WTB: NEW lower rad hose
    By Gregzilla in forum Want to Buy
    Last Post: 08-11-2008, 05:23 AM
  3. NEED to lower my car
    By gram0019 in forum GTS Tech
    Last Post: 06-19-2007, 10:48 AM
  4. WTB: Lower control arm
    By R32FIEND in forum Parts for Sale
    Last Post: 10-06-2006, 02:14 PM
  5. cheap way to lower your car
    By Daryl @ RightDrive in forum General Skyline Discussion
    Last Post: 02-19-2006, 12:56 PM
