Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: crankshaft pulley options
    Sep 2011
    vancouver
    10
    my crank shaft pulley is visibly off axis and making a loud clunking noise. hopefully i just need to tighten or replace the pulley, can anyone tell me if the cs pulley from any rb, r or ka will work with my rb20
    GTRCer evilgtr's Avatar
    Jun 2009
    Moose Jaw Saskatchewan
    837
    Buy a new one, I custom ordered a 850hp crank damper from ATI so I could run a 800hp with Air conditioning and it cost $485 shipped.
    My old RB26 pulley weighed 13.0 lbs my ATI pulley weighed 9.99lbs , thats a lot of weight to remove in rotating mass.
    I noticed the response in my engine and the entire job start to finish took less then 2 hours.
    Sep 2011
    vancouver
    10
    looking for a cheaper fix i see alot of part for rb25s and r32 wondering if they would work
    Jun 2009
    837
    Im almost certain a RB26 one will work
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,897
    + 1 for the ati pulley im running the same one
    Jun 2009
    837
    Its cheap insurance and they come assemled and with warranty.
    ***Just some advice - OEM crank pulleys get balanced with the crank so if you replace yours with another one you might still be in the same position***
    Dec 2008
    GTA
    440
    Who else has upgraded their pullies?
    Been interested in doin mine on my rb25
    GTRCer BrianV8's Avatar
    Aug 2008
    Kamloops
    2,051
    i'm also interested, purchased an rb26 one myself hoping to use it on my rb25 but found out the power steering belt is different, rest is close to the same. I also don't want to blow 500 bucks on an ati but has to be a happy medium.
    Like has anyone tried anything like this
    http://www.ebay.ca/itm/Nissan-Skylin...item336b7e6e0a
    Like end of the day its just a pulley as long as it get balanced with rotating assembly or at least on its own then how can this be any worse?
    M13
    M13 is offline
    GTRCer M13's Avatar
    Oct 2007
    604
    3,652
    I severely doubt a 20+yr old OEM balancer is still balancing like they used to.
    ATi or Ross is good.
    Jun 2009
    837
    I consider The balancer as one of the most important parts of the engine so spend a few extra dollars and invest wisely in a after market pulley.
    Replacing a faulty OEM pulley with another OEM pulley is like changing your oil and adding used oil with less km's
    A new ati damper sells for around $375 that's a cheap insurance policy for your crank and oil pump
  1. Replies: 0
    Last Post: 02-25-2011, 02:26 PM
  2. URGENT WTB : RB20DET Crankshaft pulley bolt
    By qu0vad1s in forum Want to Buy
    Last Post: 05-31-2008, 08:54 AM
  3. RB20DET crankshaft pulley options?
    By qu0vad1s in forum GTS Tech
    Last Post: 10-08-2007, 11:01 AM
  4. r33 crankshaft
    By tardo00 in forum Parts for Sale
    Last Post: 02-16-2007, 03:53 AM
  5. FS:never used GTR Crankshaft
    By nismo2006 in forum Parts for Sale
    Last Post: 08-21-2006, 02:25 PM
