View Poll Results: DISABLE HICAS OR KEEP IT?
Voters
32. You may not vote on this poll
  • Fix HICAS
    5 15.63%
  • Delete HICAS
    27 84.38%
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Disable hicas or keep it?
    GTRCer clone's Avatar
    Aug 2010
    Caledon
    226
    DISABLE HICAS OR FIX IT.
    What do you guys think about HICAS.
    right now I believe I have a problem. I just got my alignment done, and on occasion my alignment corrects itself 3" to the right.
    Jun 2011
    Toronto
    1,562
    Get rid of that s***.
    I had the exact same issue, Hicas had a mind of it's own, and my car would crab walk a lot.
    Send Daryl from RightDrive a PM, he got me a Tomei Lock Out Kit in a week. It's $200 for the kit and about another $200 for installation. I got RightDrive to install the lock kit and they did A+ work, from the lock out itself to disabling the Hicas ECU from throwing codes.
    Hope this helps!
    Because race car.
    GTRCer gtrjon's Avatar
    Sep 2010
    vancouver
    1,897
    the way i look at is if your hicas works fine with no problems, no codes no hiccups then keep it but at the first sign of problems junk it
    GTRCer TrevoR32's Avatar
    Oct 2006
    G.T.A
    569
    i hate how it engages, i notice it worst on on-ramps go above 80 or so and a nice linear curve turns into an unwanted tight cut to the inside :S
    2009 Infiniti G37XS
    2003 Sentra SE-R Spec V
    2003 Acura MDX (Gave to Brother)
    1991 Nissan Skyline GTR
    2012 Nissan Murano
    GTRCer Skym's Avatar
    Sep 2007
    South
    6,702
    Lockbar or non HICAS rear subframe which is better for track use due to removing the troublesome balljoints. Then remove parts in rear off HICAS powersteering pump, reroute hoses, etc.
    As far as I know, HICAS should engage when turning steering wheel over 90 degrees (steering angle sensor). Or should only work above 70km/h? (speedo cable). Both are shown in R32 catalogues.
    Here for 90 degrees or under and above 70km/h? -
    http://www.ne.jp/asahi/tomosang/skyl.../photo/k15.jpg
    Over 90 degree corner -
    http://www.ne.jp/asahi/tomosang/skyl.../photo/z17.jpg
    HICAS is used to remove understeer in factory setup, as shown in the over 90 degree corner link with what happens to car without HICAS.
    Fitting upgraded swaybars, adjusting ride height, playing with alignment, etc are ways to reduce or remove the understeer after removing HICAS.
    Aug 2010
    Caledon
    226
    I had a good experience with right drive, I'll probably get them to do it this winter.
    GTRCer DreadedFist's Avatar
    May 2005
    Port Coquitlam, B.C.
    1,667
    Best way to get rid of it is to rip entire system out all the way to the front of the car, then loop the power steering line to the PS cooler. You can use a lockbar but you'll still have the craptastic tie rods and ball joints. You can get kits that eliminate those as well, replacing them with toe (?) arms. Or if you're feeling adventurous, swap in an r32 non-hicas or s13 non-hicas subframe. Locking it out with a lock bar is easy. But you should rip the rest of the crap out too. It's all pretty heavy and once hicas is locked, it's just sitting there taking up space
    GTRCer gtrjerry73's Avatar
    Apr 2011
    spruce grove alberta
    246
    i dont know i havent been on the track as ther is a shortage of them in my area, but i have taken a few corners with some speed and i really do think that the system does have merit. did the old group a cars have this system taken out of the car? but for every day street use yes obviously its probably not worth the investment to keep it. but if i did alot of autocross and circuit racing i would definately fix it.
    esh
    esh is offline
    May 2009
    Toronto
    372
    Even for autocross or circuit racing lose it for the weight savings. Like skym said, it does help with understeer but that can be corrected after.
    Here's a good DIY write-up
    How-to - R32 GTS Hicas removal
    Aug 2006
    Saskatoon
    373
    ams has a group buy on right now
    oh hai!
  1. FS: Tomei HICAS Lock 2 (Eliminates HICAS)
    By dk89 in forum Parts for Sale
    Last Post: 05-10-2011, 08:51 AM
  2. Replies: 12
    Last Post: 04-05-2011, 09:32 AM
  3. for disable the Speed limiter for free
    By FLYSKY in forum GTS Tech
    Last Post: 03-27-2007, 01:14 AM
  4. Hicas light on, hicas removal bar in place.
    By Inline Slut in forum GTS Tech
    Last Post: 12-05-2006, 11:19 AM
  5. Replies: 9
    Last Post: 05-13-2006, 02:31 PM
