Ok guys I need a little help.
I have done some research, and not much has helped.
So here's the story:
My r32 gtst rb20det has a weird spitting problem. It used to happen at around 4500rpm. It would spit backfire and black huffs of smoke out the exhaust. I changed the fuel filter. Had a vacuum test done, checked the plugs, and compression came strong with 165 across all 6. No errors on the ecu. But I will double check that.
Recently in the colder weather it would start sputtering at around 2500 and as the car got warmer it would reach 4500 start sputtering and some times the car runs flawless and pulls really good.
Any help is appreciated.
Thanks in advance.
I would like to add that it's making full boost, car is stock, except hks bov. I just bought a wideband and after market boost gauge but I have yet to install.
LinkBack URL
About LinkBacks
battery is new, and all lights stereo come on strong. And theres half a tank of gas in there.
